flash9
The other day I found a rather large spring under the passenger front seat. The spring is ~10" long, ~3/4" coil and made of ~1/8" round steel. I looked under the drivers seat and found it appears to do nothing more then to give resistance when someone tries to rotate the knob backwards to lean the seat back.
I took out the passenger seat to try to re-install the spring. Upon pulling the seat out I quickly noticed the metal post the spring hooks onto was sheared off and there was no way I was going to be able to re-install the spring. It really does not seem to effect the performance of the seat in any major way. Anyone know differently?
Then I re-installed the seat back into the car, but I forgot to clip the three wire connectors under the seat. When I started the car the Air Bag Warning light came on. I stopped the car and reconnected the three wire connectors, but the Air Bag Warning light is still on.
Will this reset itself, or do I need to find someone with a Vag-Com to reset it?
Thanks for your help in advance.
