Cleve
- Joined
- Nov 10, 1999
- Location
- Southern Ontario, Canada
I was reading a thread on VWVortex re: the infamous oil question. SOmeone who sounds that they know what their talking about had this to say re: syntec & Delvac 1:
"I don't think that people need to be as concerned as they are about using only CG-4 oil in their TDI. The European ACEA 'B' specifications for passenger diesel engines, which both Mobil 1 and Castrol Syntec meet, don't have exact API equivalents. The 'B' specs are more demanding than CF, so conventional CF oil won't cut it, hence the switch to synthetic. But CG-4 is more like Europe's heavy-duty *commercial* 'E' rating, which is probably overkill for a passenger diesel.
Delvac 1 5W-40 has a higher viscosity (more turbo lag, less hp), higher phosphorous content (bad for cat), more residual ash, a lower flash point, and worse cold-flow characteristics than Mobil 1 or Castrol Syntec 5W-30. It's only "benefit" is a rating (CG-4, ACEA E5) that is higher than you need. Given that, I think that using Delvac 1 instead of the specified Syntec may be counterproductive."
Some fo the benefits of Delvac 1 that I've taken as gospel seem to be contradited by this persons statement. Especially this one:
"Delvac 1 5W-40 has a higher viscosity (more turbo lag, less hp), higher phosphorous content (bad for cat), more residual ash, a lower flash point, and worse cold-flow characteristics than Mobil 1 or Castrol Syntec 5W-30."
Where I live, we can expect sometimes weeks of -20C or less weather. Is Delvac the right oil for this climate, or does it perform better in extreme heat? Should I be using one for winter, and another for summer?
