Hello please help,
my situation:
2010 Jetta Sport wagon TDI DSG
86000 miles
I live in Arizona
check engine: P0266 Cylinder 2 Contribution/Balance Fault
Engine still starts fine, fuel economy is not changed, engine does NOT run rough to my knowledge, no strange smoke coming from tail pipe, etc.
Mechanic gets it on bench(checks fuel solenoid for metal debris, none is found, checks some numbers on the computer readings and says cyl2 injector is not changing values like the other 3 and recommends replace injector)
I agree and he installs a new cyl2 injector (650$). He says he cleared the adaptation values on all the injectors within the ECM and drives the vehicle for 4 cycles and no problem, then returns the car to me. car drives fine till following morning. He warns me this problem may not be over...
next morning when cold (52F out this morning) I get the code P0263 Cylinder 1 Contribution/Balance Fault. Call him up, he recommends replacing cyl1 injector.
I call dealer for some fact finding. I friggin cant afford to replace all 4 at 650 a pop. The dealer asserts that P0263 and P0266 can also be indicator of failing glow plug. (my dash cluster does not show a flashing glow plug or anything while driving). If I have glow issue, I don't care, I will not need them in the mild climate I live in and I don't want to spend 2K to make a light go out "if" my car drives fine.
Car appears to run ok but has a has a solid check engine light P0263. Please, can anyone recommend what to do. I have used this mechanic b4 and trust his abilities and he knows his stuff, but I am moving in a week and i don't want to drop 2k on this workmanship and not be able to make good on the parts/labor warrantee as i will be in a different state and unable to take it back to him if there is issues.
Things im thinking currently:
Will injector cleaner be worth a try?
Changing glow plugs and/or glow plug cluster wires
Why are my injectors going south with only 85K on the engine?
Fuel filter replacement?
Thanks in advance....
my situation:
86000 miles
I live in Arizona
