WindsorFox
I'll put up thoughts when I switch to stock and see. Was it worth six bills? No. Would I do it again? Probably, but I'm like that. Will I take it back for refund, no unless I someone local could provide something better.
I'd say that with increased torque, there is a likelihood of more wear. Of course driving style and technique could also have ill effects on the drivetrain. On a slightly more extreme case, I recall the Audi TDI race cars were destroying transmissions during initial testing because the diesel had significantly more torque.Is there any consensus on weather or not chipping can harm any other parts of our cars? Is it degrading to the transmission after 80 or 100,000 miles?
The first question has to be - which transmission do you have?Is there any consensus on weather or not chipping can harm any other parts of our cars? Is it degrading to the transmission after 80 or 100,000 miles?
I have DSG. And I'm looking mainly for MPG. I would be concerned however, about any times I was stuck in traffic or in a city, that my tranny was being worn prematurely by the extra torque. Is there a reason why VW dont build the cars to these specs in the factory if all that is needed is to add a chip and it benefits MPG and performance? Is it detrimental in a to some other system?The first question has to be - which transmission do you have?
If you have a manual transmission, your only worry would be the clutch. How long a clutch lasts has more to do with the way you drive than with the engine's torque (within limits). The transmission itself is beefy enough to easily stand up to a stage 1 or even stage 2 tune.
If you have a DSG transmission, things get a little more complicated. The DSG's controller has the ability to limit engine torque during shifts. This is very annoying to some people. Malone Tuning recommends a DSG tune along with an ECU tune. However, this adds to the cost and the jury is still out on what this will do to the long term life of the transmission and its clutches.
Have Fun!
Don
VW sells (more or less) the same engine in Europe with 170HP vs. 140HP here. The biggest difference is probably emissions standards. Europe and the US have different priorities as far as emissions are concerned. In the US they are mostly concerned with particulates (soot) and Oxides of Nitrogen (NOx). In Europe they are more concerned about soot and Carbon Monoxide (CO). With differing emissions standards to meet, there are different exhaust systems and different tuning.I have DSG. And I'm looking mainly for MPG. I would be concerned however, about any times I was stuck in traffic or in a city, that my tranny was being worn prematurely by the extra torque. Is there a reason why VW dont build the cars to these specs in the factory if all that is needed is to add a chip and it benefits MPG and performance? Is it detrimental in a to some other system?
^Is that on the APR tune like this thread is about or the Neuspeed tune you have in your avatar?
I'm glad someone else pointed this out. Way different from what I used to drive. I noticed the sharpness when she is moving from a cold start. 1st gear just rolling along, come off the throttle then back on ever so gently and it bucks so hard that the wheels slip on smooth concrete.One thing that has been driving me nuts about my 2012 Golf TDI Manual is the sharp throttle on/off transitions, that are apparent in some driving situations. I drove a 2013, which does the same thing so I am assuming this is a normal side effect of our ECU programming for emissions, and DBW system....
Some in this thread have said that the car drives much smoother with the APR tune, can anyone give more details on what is smoother?
It's a stage I tune, it should be a noticeable difference compared to stock according to their advertised numbers.Well you can't expect huge seat of the pants feel on this as it doesn't change the drivability. The APR stage 1 is also compatible with your warranty. On mine it tool some time to settle in and it is less noticeable if you just nail it from a stop rather than actually drive. And as you mention, the working of it is a little complicated, make sure you actually have it turned on.
I was told that APR did collude with VW on their tune.It's a stage I tune, it should be a noticeable difference compared to stock according to their advertised numbers.
And ANY tune effects your warranty, period. If you tune your car with any aftermarket company no matter who it is; it effects your warranty. VWoA has not partnered with any tuning companies to offer OEM warranty coverage on their tunes.
The level of that effect is pretty much up to each individual dealer (MM Warranty act and all that fun stuff); but I can guarantee you if your ECU fails, or any part they can attribute to your tuned ECU, VW is not covering it...
Probably by your APR dealer, right?
No; they did not. APR has worked with VWoA on specialty vehicles, Police vehicles, etc; but they are not "accepted" as warranty safe BY VW for the public.
Aaah; no idea. Yeah, they may have colluded; but it still doesn't make them warranty safe...
And yes; I know that 100%
