Hi all.
I have bought a newer VW Sharan 7N from 2015, 2.0 TDI CR 140hp, DSG, and I have noticed white foam/crystals near the connection from the line to the (AdBlue) injector after the DPF.
Would the problem be the connector (part of the line) or the spigot on the injector itself?
Is this a common problem and can I get VW to change it under some sort of extended warranty?
Or could I be so lucky that there is an easy fix?
