Old October 12th, 2017, 10:56   #1
leocat66
Angry Emissions Modifications Results suck
Our 2013 Passat has had the Emissions Modifications installed. What a disappointment. We expected some minor issues as described in the notice from VW. Our car, 60k, now sounds like our '99 which has 300,000 on the clock. Hesitation issues abound and it is now necessary to start off from a stop in S mode and not shifting into D until around 20 mph. Someone will ultimately be killed due to the hesitation issue. Our '06 Jetta has much more performance. When the issues were presented to the dealer they could not care less.
Anyone else having similar issues?
leocat66 is offline   Reply With Quote
Old October 12th, 2017, 16:36   #2
dak503
When i had the modification done on my passat i had the same problem. It was so bad even my wife noticed it and she doesn't notice much when it comes to cars. But now if i hit the gas pedal to aggressively the tires chirp. It seems to have more power off the line than before. I think the car needs some time to relearn everything. I hope that is your problem drive it for a bit and see if it gets better. Hopefully that all it is.
dak503 is offline   Reply With Quote
Old October 12th, 2017, 21:32   #3
jrm
Fuel Economy: 42/52
yup, Emissions comes first- been this way to some extent since 2008- mine is also delayed- if you mash it to the floor there is a good solid 2 seconds of nothing, just idles then at that 2 second mark it comes to life and will spin the tires, so plan ahead when pulling out across busy lanes of traffic on those left handers But to be honest, my dodge ram diesel is 10 fold worse, randomly it disconnects from the pedal sensor and I can leave it stomped for 30 seconds as it just idles and speeds drop to a stop when pulling a travel trailer- called dead pedal and extremely common. We all know the fix. $2K and a trip to mexico to make some parts fall off
2013 Passat TDI SE+NAV 48MPG
2001 Honda civic 40MPG
1985 VW idi 1.6 Golf 55MPG http://www.youtube.com/watch?v=yo-YUR1_DaU
1996 Dodge mechanical Cummins 12V 2500 4x4 that gets 20MPG
1990 Toyota xcab 4x4 3.0 v6 (3.slow) 15MPG
jrm is offline   Reply With Quote
Old October 13th, 2017, 04:44   #4
Rico567
If you can't get these problems to go away, you may be eligible to switch to the buyback. Our '13 Passat doesn't have them, because we're not even thinking about the fix. Doing the buyback late next year.
"I reject your reality and substitute my own."
- Adam Savage
Rico567 is offline   Reply With Quote
Old October 13th, 2017, 19:36   #5
bustNfuel
bustNfuel's Avatar
Fuel Economy: 39-42
Mine is a '13 with 64K miles.
After the emissions update, I never really noticed any changes in the power delivery, sound, nor the way the DSG operates. It always seemed to be somewhat hesitant between brake release and actually moving away from a stop which is annoying. Not enough for me to consider it unsafe. I had to learn the DSG's idiosyncrasies compared to driving with a torque-converter automatic when I first started driving it. So to recap, thankfully mine did not exhibit any noticeable changes after the emissions mod.
Give it time. Probably a tank-full to see if it's returned to normal..'re-learned'.
'13 Passat SEL ● TDi DSG ● 60K+ miles
bustNfuel is offline   Reply With Quote
Old October 16th, 2017, 07:28   #6
roni024
Where did you get this information from?
I've been holding off on both the fix and buyback to extend my "free" driving time, but if what you say is true, I may want to get the fix sooner to be able to determine any problems associated with it before the Dec 2018 deadline. As it stands now, I'm leaning toward the fix.
roni024 is offline   Reply With Quote
Old October 16th, 2017, 07:59   #7
740GLE
From my knowledge soon as you get the "fix" and VW states you're car is "operating as designed", buy back is off the table.
Now i'd be up to each person and dealer to determine "operate as designed", somehow I think an owner could scream until their are blue in the face and VWoA would stand their ground, and then the dealer would probably low ball an offer for a trade out of good faith.
Old October 16th, 2017, 16:47   #8
06bluebeetletdi
How many miles since modification? Are you more city or highway driving? I am at 1800 miles with my passat, 90% at 70 mph, it seems plenty peppy and fun to drive, i dont notice any difference other than increased regens.
06bluebeetletdi is offline   Reply With Quote
Old October 18th, 2017, 07:16   #9
leocat66
Modification was made in late August. 1400 miles since modification.
Old October 18th, 2017, 07:21   #10
leocat66
Has anyone tried the options offered by KERMA TDI. Seems that they offer options to improve performance and noise issues on all TDI vehicles, relating to emissions either before or after modifications. If what they say is half true, it is awesome.
Old October 18th, 2017, 10:55   #11
Owain@malonetuning
Both Kerma and Malone have been tuning these vehicles for quite some time, should have no problem there. Mark has considerable experience with the bosch EDC17 ECUs found in most of the newer diesels, we tune pretty well every diesel coming out of Europe at this point.
Dealers - malonetuning.com/dealers
We made a free VCDS Log Viewer!
Owain@malonetuning is offline   Reply With Quote
Old October 20th, 2017, 19:20   #12
jrm
Fuel Economy: 42/52
I have noticed that after the update that cold weather really causes this thing to drink fuel, in cold EGT temps dip down to 400F in rain, then the engine changes pitch and instant fuel MPG drops by 5mpg and the EGT's spike up to 950F
Old Yesterday, 06:56   #13
Jetta_Pilot
Jetta_Pilot's Avatar
Location: West Hill, Ont. Mexico mid October 2017 to end of April 2018
There are three different people complaining about a lag of (2 seconds?) after releasing the brake pedal. It just seems like 2 seconds, it isn't.
What you are experiencing is the hill hold. This keeps the same pressure on the brakes for a fraction of time as you applied at the stop.
There are two ways to rectify this.
1.) Using a VCDS disable the hill hold function. (Personally I like it)
2.) Anticipate when the light changes to green and release the brake pedal just before that.
All interior bulbs to LED. Several VCDS modifications. Darker window tint. EVO skid-plate. Malone Stage 2, Winpower Projector headlights. Angel eyes.LED DRL's.Average 1 year 30/6/16 to 30/6/17 - 50.71 Mpg - 5.56 L/h
Old Yesterday, 13:34   #14
Rico567
Originally Posted by jrm View Post
I have noticed that after the update that cold weather really causes this thing to drink fuel,<snip>
We have had no update done, and don't plan on it, and our Passat has gotten lower mpg in cold weather since we bought it new.
- Adam Savage
Old Yesterday, 22:04   #15
jrm
Fuel Economy: 42/52
Rico, prior update in cold weather we averaged low 40's now we are low 30mpg range- worse than my old Accord V6
Jetta pilot- the lag I'm talking about isn't hill hold, but you must stomp the pedal to notice it- if you slowly floor it the car reacts pretty good. I think its a dsg safeguard. I really noticed it when chasing a thief (robbery actually) and whenever I stomped the pedal from a 4 way it lagged big time. Cops took over after we got out of town and got him- Passat hung with him just long enough to get the direction that he exited town.
EPA moving to ban emissions modifications on certified vehicles, even for off-road bhtooefr TDI (Diesel) Emissions 78 February 14th, 2016 11:26
What is the policy regarding emissions modifications? cevans TDIClub and TDIClub Forum News, Issues, Problems and Suggestions 9 September 6th, 2015 18:05
Suck dsmith1279 VW MKV-A5 Golf/Jettas 5 May 7th, 2009 00:40
To suck or not to suck? That is the question... mickey VW MKIV-A4 TDIs (VE and PD) 52 April 26th, 2001 11:26
Page generated in 0.15197 seconds with 12 queries
[Output: 126.15 Kb. compressed to 105.04 Kb. by saving 21.11 Kb. (16.73%)]
