chudzikb
I have not seen may how to's on this site but here goes.
1) Obtain fuel filter got mine from local auto parts place for about $37 U.S.D.
2) I removed the air tube between the air box and intake. Probably not necessary, but, provided lots of room.
3) Removed the clip from the top and pulled the plastic clip off of the filter (I used plyers, but, probably could do with hand)
4) Removed the hoses from old filter, took a little twisting, but, they came off easy enough.
5) Lossen the screw that retains the old filter, mine was a phillips head and was pretty loose.
6) Install new filter into clamp and tighten screw.
7) Install the plastic top and retaining clip.
8) Install the intake line from the fuel tank.
9) I put my vacuum pump on and pumped until fuel came out the outlet (no sputtering or cranking on the restart)
10. Replace outlet tube to engine.
11. Reinstall air tube.
12. Start and check for bubbles. (had a few at first, but, they went away soon enough)
No reason for anyone on this list to pay to have this done, it does not get any easier.
BEC
96 Passat
98 Jetta (wifes)
BEC
96 Passat
98 Jetta (wifes)
