Helven Ink
allright, so I noticed a little while ago that there was oil dripping from the bottom of my oil filter housing. That kinda cube shaped dealy with the big black plastic hex bolt thing on the bottom of it.
Could someone tell me what size that hex bolt is? and if there is a conveniant tool I could use to tighten properly without taking off the entire housing?
I have a 99 Beetle, and an A/C hose is the way, and I'd really rather not have to disconnect that either.
I need to stop thinking that my car is fixed... as soon as I do, things start falling apart. I thought all I had to do was replace my injector nozzles, but no... I have to replace my injector nozzles, my cat. converter was clogged, my oil filter housing is leaking all over the place and it would seem that my brand new intercooler has cracked. (though I'm not sure if it's the IC or one of the pipes connecting to it, but I have no boost) Would a cracked IC cause I high-pitched whistleing noise that sounds like it's coming from the turbo? my turbo seems to be fine, but...
I'm starting to wonder if maybe my car doesn't like me...
P.S. aside from my question about the oil filter housing bolt dealy, I'm just ranting... it makes me feel better...kind of.
