2003 Jetta. 75,000. Miles Manual.
The low-beams do not com on. Whether the light switch is on or off, the low-beams do not work. All other lights work. All fuses are good.
I pulled the right side headlamp to see if by some wierd comic happening, both lights burned out at exactly the same time. The bulb looks good. I checked the main fuses over the battery, all connections look clean and good.
I rarely if ever use the high-beams. I don't think that the swith has been used 20 times in the last year (other than today while troubleshooting.) The emergency brake is dis-engaged and the "brake" light on the dash is off.
Any ideas?
Ferg
Any ideas?
Ferg
