Go Back   TDIClub Forums > Picture Gallery/Specs of Members' TDIs > Other TDI/Diesel Picture Gallery
Other TDI/Diesel Picture Gallery Do you have a TDI or Diesel not listed above? If so write a message here describing it and insert a picture if you have one. If you don't have one on the computer, email me and I'll give you my address and I'll scan it for you. If you need web space for it, email me as well. Please make a short yet descriptive title for your vehicle.
Old July 25th, 2016, 09:17   #1
nokivasara
nokivasara's Avatar
Fuel Economy: 44-49 mpg
Default 2008 Skoda Octavia 4x4 TDI (RRP)
I bought a new car today
It's a Skoda Octy TDI 4x4 with rough road package, ie steel belly pan and some sturdy protective shields underneath the body and control arms and a bit more ground clearance. I think it's as tall as a Scout.
230k km, everything seems to be in good order I think.
nokivasara is offline   Reply With Quote
Old July 25th, 2016, 10:00   #2
bobt2382
bobt2382's Avatar
Fuel Economy: 46.5
Nice! !
2010 4D CWhite Golf TDI, 6 sp manual, Fluidampr, Bixenons, Rear Airbags, RNS-510, Dynaudio, DieselGeek SS & P2015 bracket, Force Fed Eng. Shifter Bushings. XB,UB, & RB UNIbraces; TyrolSport Brake Caliper Bushing, 2Micron Contain/PureFlow kits & timing belt cover, PolarFis MFD module, Euro light switch, R Red LED Tail Lights,Under Seat Drawers, Full color MFD cluster.
bobt2382 is offline   Reply With Quote
Old July 25th, 2016, 19:24   #3
brnsgrbr
brnsgrbr's Avatar
Fuel Economy: 44 mpg
Sweet
Sent from my iPad using Tapatalk
2.0Ltr ALH w/BHWs, WB girdle, IE Tuscan rods, RyanP GtB2260Vk kit, 4bar MAP; Kerma 3" exhaust w/HF cat & Aeroturbine 3030XL, headwork, DRW 6speed w/DG Sigma shifter;SBC S2 End race clutch W/ferramic disk; Peloquin TBD; Bosio Stage 2 R520s; DLI Technik mounts ; 11mm; TT CA bushings; DG Panzer FMJ, RP,& 100K TB&SB upgrade; Coolant heater; DRL & EGR deletes; ventectomy; Accuair/Airlift suspension;B20-B100
brnsgrbr is offline   Reply With Quote
Old July 25th, 2016, 20:26   #4
GetMore
Fuel Economy: 56.1/42.7/38.1
I am envious. I wish we had something like that here.
1997 Passat TDI, RC2, RR .216 injectors, needs a headgasket. For sale.
2010 Jetta Sportwagen, 9W7, Euroswitch, Ed's lights, fog lights, mud flaps, Malone Stage 2 and DSG tunes. Still has full emissions.
GetMore is offline   Reply With Quote
Old July 28th, 2016, 07:06   #5
nokivasara
nokivasara's Avatar
Installed my Led spot lights today, they are mounted on a plate that's attached between the license plate and the bumper, that's the standard way of mounting auxiliary lights up here.
Normally there is a cross member behind the bumper but the Skoda has nothing, there's a huge gap to the beam so I used 8 M5 screws and nyloc nut with large washers, pretty sure it will do.
Did not notice that the first pic was so blurry, sorry for that. At that point the plate is mounted with 4 screws, then I put the remaining 4 through the license plate holder/frame and the light mounting plate.
Next pic is just a test how the lights looks, the plate is screwed with self tapping screws here, this was before pic 1:
Almost done, not wired in yet. Will probably have to add some support bars to the top of the lights.
Old September 5th, 2016, 01:07   #6
nokivasara
nokivasara's Avatar
We just got back from a road trip, didn't take many pictures but got a few nice ones (of my car )
First trip with my new Octavia, went really well but the rough road package with added ride height and beefier suspension does make the suspension a bit too hard, especially with 17" wheels. I think I'll change to 16" next year.
I got 40 mpg on this trip, I think it's ok considering it's a 4x4 and the roads weren't flat.
It does regen pretty often, the PO had a very short commute and probably got a lot of interrupted regens. There's no DPF warning light lit so I hope it will be able to burn off enough ash eventually that I don't have to clean/replace the DPF.
Old September 5th, 2016, 19:18   #7
FordGuy100
FordGuy100's Avatar
I wish we could get those here!
04 Jetta BEW/5 speed TDtuning stage 1 Straight Pipe, 278k, 1985 F250 6.9IDIT. 05 2500 burb 4x4 ex govt.
FordGuy100 is offline   Reply With Quote
Old September 9th, 2016, 10:10   #8
MP517PRCT
Fuel Economy: ~45mpg in the JSW, ~56 in the '05.5
That is awesome! Almost everything I want in a vehicle... Diesel engine, check.... manual transmission, check.... 4 wheel drive, check... good fuel economy, check.... interior room, check! what's not to love???
Why do the marketing geniuses in this country insist on pushing gas guzzling SUVs for soccer moms (no manual, no diesel, poor fuel economy) or little clown cars for teenagers (no diesel, no 4WD, no interior room) on consumers here.
If this type of car was available in the US, I would sell my 09 JSW TDI, 06 Jeep Liberty 3.7L Gas, and my 05.5 Jetta TDI in a heartbeat, and buy two of them!!!
MP517PRCT is offline   Reply With Quote
Old September 11th, 2016, 11:38   #9
da.hs
Would be a near perfect work car for me, if available.. ah well, time to load up the 4Runner. Out of curiosity: is it full time 4WD or switchable?
da.hs is offline   Reply With Quote
Old September 12th, 2016, 09:56   #10
nokivasara
nokivasara's Avatar
It is a full time 4wd, a 2nd generation Haldex. From 2009 and onwards they have Haldex gen 4 which is a proactive rather than reactive like the gen 2. That means that in my car, when starting from standstill, the front wheels have to slip before any power is transfered to the rear wheels, where as the gen 4 starts in 4wd mode.
I think that's how they work, but haven't researched it so I'm not 100% sure.
Old September 16th, 2016, 10:22   #11
nokivasara
nokivasara's Avatar
Swapped the spotlights to a led light bar, it's a 75w cree bar. Not as bright but better than with just the stock lights, that's for sure.
On our Golf I put a light bar inside the lower grille, on this I mounted it as high as possible.
Old November 3rd, 2016, 09:54   #12
nokivasara
nokivasara's Avatar
It's winter again!
The rough road package and 4x4 really is nice to have, this is where I work
Old November 3rd, 2016, 16:09   #13
bobt2382
bobt2382's Avatar
Fuel Economy: 46.5
Nice. I see you work in the center of town, lol. Keep the pictures coming!!
Old November 3rd, 2016, 16:50   #14
HBarlow
It's not "marketing geniuses" who are responsible for those decisions. It's government that overregulates and taxes diesels and simple minded American buyers who think diesel engines are evil and prefer gasoline engines and electric go carts.
Harvey Barlow
US Navy Retired
Crosby County, TX
2016 Audi Q5 TDI
2009 VW JSW TDI (awaiting buy back)
HBarlow is offline   Reply With Quote
Old November 5th, 2016, 09:00   #15
nokivasara
nokivasara's Avatar
Yeah, I have a low-stress environment to work in! Unless you get wound up by having wolves and bear around you
I'm a forester, this was the scenery I got to spend my day in yesterday:
octavia 1.6 tdi kylobeddo General Automotive 0 August 14th, 2014 07:50
2008 Jeep Laredo 4x4- trade for a TDI! TDI_01 TDI Cars for Sale/Wanted 7 October 27th, 2010 15:42
octavia tdi goes nuts far_cry TDI 101 4 December 30th, 2009 14:18
Car and Driver: 2008 TDI Jetta named one of 2008's most fuel efficient surprises Tahna Los TDI News/Tech 162 February 3rd, 2008 15:50
Skoda Octavia TDI's Stateside? Arcturus VW MKIV-A4 TDIs (VE and PD) 9 June 7th, 2000 03:02
Page generated in 0.17873 seconds with 11 queries
[Output: 133.26 Kb. compressed to 111.25 Kb. by saving 22.01 Kb. (16.52%)]
