Go Back   TDIClub Forums > Picture Gallery/Specs of Members' TDIs > Other TDI/Diesel Picture Gallery
Other TDI/Diesel Picture Gallery Do you have a TDI or Diesel not listed above? If so write a message here describing it and insert a picture if you have one. If you don't have one on the computer, email me and I'll give you my address and I'll scan it for you. If you need web space for it, email me as well. Please make a short yet descriptive title for your vehicle.
Old June 13th, 2017, 04:05   #106
xjay1337
In other news, I decided to paint my front calipers to match the rears.
Before:
After:
2017-06-13_10-44-26 by Fat Bear Photography, on Flickr
Also went to AKS and got the clutch swapped out - FINALLY - it lasted about 2 days after mapping. Nearly 60k on the previous 6 Paddle and DMF kit so lasted very well indeed.
Replaced with new 6 Paddle unit and SMF. SMF comes with higher clamp force cover plate.
This was the flywheel when it came out.
20170608_140536 by Fat Bear Photography, on Flickr
The clutch plate itself had hardly worn. But the flywheel and cover plate had seen better days.
It does rattle quite a bit on idle without the clutch depressed but it revs quicker and just feels nicer in general.
Also fitted a clutch bypass switch. You always had to have the clutch depressed to start the car before but now it doesn't need that.
This was done as when fitting SMF kits it can damage the thrust bearing which can kill the engine so better to be safe than sorry.
While it was in the air we did the oil and filter. It was replaced when Bobby rebuilt the engine and now swapped it again just to be safe. Now running Millers CFS NT+ 5w40.
Done around 2000 miles on the new head turbo etc and nothing has broken or blown up
Hybrid VKLR, BSR Ported Head, BSR Valve Springs, BSR CP3, 395hp 660nm Built and mapped by Bobby Singh , THS IC, Revo/Forge Custom Intake, Mocal Oil Cooler, 3 Eurojet TBE, AKS Quickshifter, Recaro Pole Positions, Schroth 4 point harnesses, Rear seat removal, R bumper, Carbon Fibre GT24 Bonnet, VWR Spoiler, OZ 18x9 Et43, AM DB9 front brakes, Audi S3 rears, Polar FIS, Hertz Audio
xjay1337 is offline   Reply With Quote
Old July 26th, 2017, 05:40   #107
xjay1337
Got all the suspension on on Tuesday. New Bilstein PSS10/B16. It took a bit longer than anticipated so I ended up getting a lift home on Tuesday evening and collected the car on Thursday.
Also got full Superpro rear bush kit, new drop links front and rear, new rear top mounts, and some modifications to my turbo intake pipe and boost pipework.
It's amazing!! So much better. You can certainly tell the suspension is a quality item rather than a budget lowering option. It's actually ever so slightly higher than it was before now too but hey ho.
IMG_20170711_194314_205 by Fat Bear Photography, on Flickr
FB_IMG_1500282516058 by Fat Bear Photography, on Flickr
Tested it out at Donnington Park on Sunday at VAG Tuner VW show.
As a package it was very, very capable. Next chassis mod is a LSD but given the power and torque it does manage really well without one.
Unfortunately I got black flagged twice as I was tripping the noise meters ... 98db driveby, I was around 101 db.
Few pics from the trackday a week ago. The car behaved perfectly.
Cheers Jhk__photography for pics. by Fat Bear Photography, on Flickr
Old August 16th, 2017, 22:18   #108
jerrymander
jerrymander's Avatar
Fuel Economy: 286 lbft
This is the car we wish we had over here. Maybe in 20 more years I'll be able to import one...
jerrymander is offline   Reply With Quote
Old November 1st, 2017, 13:55   #109
xjay1337
I'm sure you could just pretend it's a Golf and import it earlier, right?
Few updates!!
I did a day at Cadwell. Had to bleed my brakes in the paddock as I just didn't have time prior, and the first session boiled my fluid.
No issues for the rest of the day.
EN9I8739-3 by Fat Bear Photography, on Flickr
A video from my friend in his 310hp Mk5 Edition 30 chasing, with similar handling mods.
https://youtu.be/QoRQGNhLvVA?t=189
And onboard for a couple of laps, following a TTE420 powered ED30 - https://www.youtube.com/watch?v=Kf6T81cX9sg
And also at Silverstone on Sunday.
I did try to get some footage but my camera didn't save it!
CT-2130-(ZF-6182-13377-1-002)-1 by Fat Bear Photography, on Flickr
My 1st gear synchro has broken so the work around was either to wait 5 or so seconds from pressing the clutch down before engaging 1st, or put it into 2nd and then straight into 1st.
This worked for a while but now 2nd gear has done the same. Which makes the car incredibly difficult to drive around town.
A few weeks ago I bought a gearbox from Ebay to be rebuilt with a limited slip diff (Peloquin) and all the internal strengthening mods. Alex from AKS is a very busy guy and finally got around to stripping it down.
received_10155918928887244 by Fat Bear Photography, on Flickr
I am not sure when the gearbox will be ready but I'm hoping soon then it's just a case of getting everything swapped over.
Car is now at 188k and having done 4 trackdays since being rebuilt and not having any other mechanical issues.
Old January 5th, 2018, 17:02   #110
xjay1337
My gearbox issues have finally been fixed. The new gearbox with LSD and other modifications has been installed and works perfectly. Very happy, completely changes the driving characteristics, and it's nice to have 1st and 2nd gear back.
received_10156039073962244 by Fat Bear Photography, on Flickr
received_10156042100272244 by Fat Bear Photography, on Flickr
received_10156060794312244 by Fat Bear Photography, on Flickr
20180104_114121 by Fat Bear Photography, on Flickr
20180104_153426-01 by Fat Bear Photography, on Flickr
Old January 5th, 2018, 21:22   #111
3L3M3NT
3L3M3NT's Avatar
It's great to see that you got the trans sorted out and beefed up. What LSD did you go with?
Fix if you're using Chrome: Chrome fix
Firefox fix
RTDI Build Thread
3L3M3NT is offline   Reply With Quote
Old January 8th, 2018, 10:32   #112
xjay1337
Cheers ... made such a difference ..
I went with a Peloquin. My friend had put one aside for me.
The new gearbox feels lovely and tight, hopefully it will last me the rest of the time I have the car.
I aim to have more news regarding power soon.
Old April 18th, 2018, 12:37   #113
xjay1337
Not a full update (I will update soon) - but we achieved this today.
395hp
Around 660nm
No nos (straight diesel)
20c+ ambient temps.
2018-04-18_07-33-09 by Fat Bear Photography, on Flickr
edit: Further update
Had a bit of a nightmare over the last few months.
So we had a new turbo built. It has some very fancy wheels.
however being brand new, when it was first fitted it had a very loud high pitched whining which was not normal upon initial installation.
we had it rebuilt (again, for a new turbo!) and the balancing was so far out the balancing machine that it cut off. seems like in soviet russia, turbo balances you.
it was balanced and came back, the noise was gone but it was chugging out a lot of smoke (this is oil / white smoke , not black from fuel). this is with a 1mm oil restrictor as well
https://www.youtube.com/watch?v=WRo4C_pAyIw
So we had to have it rebuilt AGAIN. 3rd time lucky. And a lot of wasted hours for Bobby taking him away from other projects and family time.
this time by an old friend of Bobbys was brought in, who have to say did a really good job and it is much better now.
Now it was sorted we also plumbed in water cooling, and wired up a sensor to measure turbo shaft speed and got that working with factory inputs.
IMG-20180411-WA0000 by Fat Bear Photography, on Flickr
IMG-20180411-WA0001 by Fat Bear Photography, on Flickr
After a lot of tuning work from Bobby we went to Surrey Rolling Road, unfortunately it so happened to be the hottest day of the year yesterday 18th April with ambient temps between 20 and 25c
Nevertheless the end results were 395hp and 660nm torque. Very happy.
Old April 19th, 2018, 00:07   #114
Rub87
plenty ponies
Hows the smoke?
'99 Black Ibiza GT90: 2260v, ARL bottomend, rosten rods 81mm slugs, 17:1 CR, 35/38mm exh/in valves, 02M, 305mm discs with Brembo calipers, OZ Superturismo 16"x7.5J, .............
Dyno'd area, Old VNT20 setup dyno'd 192whp
Rub87 is offline   Reply With Quote
Old April 19th, 2018, 03:49   #115
xjay1337
It's good Ruben :-)
Smoke is not bad at all, no worse than before. Lots of boost to balance it out.
Old April 19th, 2018, 04:49   #116
Bobby Singh
Bobby Singh's Avatar
TDI(s): Audi 3.0 TDI
Excellent result finally Jay
Been a long time coming.
Worth mentioning bottom end is completely stock (with 190k)
Now remove the table at the back and put down a decent time
BSR
Audi A4 3.0TDI B8 - 505hp/980nm...
3.0TDI S200v hybrid (470hp) kit for sale
http://forums.tdiclub.com/showthread.php?t=492614
Bobby Singh is offline   Reply With Quote
Old April 19th, 2018, 09:38   #117
adjat84th
adjat84th's Avatar
Impressive numbers and awesome build!
Curious about this below, this is the first I've read of such a practice. My jetta's switch has been dead for about 150k miles and I actually really like just getting in a starting the car. Wouldn't mind figuring it out on the Golf
Both cars have SMF.
'01 Jetta | 17/22, 3bar MAP, 11mm IP/Lift pump, PD 150, OMI, FMIC, PP502s, SBC st3, .685 5th, Malone Stage 5
'15 Golf | GTD1752vrk, 4bar MAP, CP3, Peloquin LSD, Sachs SRE w/DMF, Fluidampr
VW updates the Scirocco BeetleGo General VW Discussion 5 February 17th, 2014 06:20
VW Scirocco andyd68 Other TDI/Diesel Picture Gallery 20 November 25th, 2011 12:37
Fifth Gear - VW Scirocco &REY General Automotive 3 September 16th, 2008 03:44
Old school VW diesel into 86 Scirocco? cujet TDI Conversions 16 April 5th, 2008 23:52
2008 VW Scirocco Confirmed tommyt TDI News/Tech 25 August 28th, 2006 15:48
Page generated in 0.18400 seconds with 11 queries
[Output: 126.18 Kb. compressed to 108.27 Kb. by saving 17.90 Kb. (14.19%)]
