Old October 24th, 2016, 08:48   #406
stover954rr
Default KILEN 65067 Coil Springs
Hey Guys,
I am selling back my 2010 JSW to VW. I currently have the kilen 65067 springs from Germany in it. I have been thrilled with them, no more saggin wagon. If someone was interested in them I would take them out and sell them.
The price is $185 shipped They only have 7k miles on them. Please pm or email.
stover954rr is offline   Reply With Quote
Old December 12th, 2016, 05:08   #407
tomsyco
Is anyone getting vibration. Under load I am getting a vibration, which I think is the CV axles. I installed the golf lift springs http://www.idparts.com/golf-lift-spr...k6-p-5930.html with bilstein touring struts. The car is tuned so under acelleration when the front end pics up a bit i get veavy vibration and its not in the wheels. It feels like it is the cv axles for sure. Does anybody think I just have a bad axel, or is it overextended?
I have a VCDS cable. Contact me. Coding for Beer
Full Rawtek exhaust with high flow cat and resonator, Malone stage II, 20% tint. Built by my hands.
tomsyco is offline   Reply With Quote
Old December 19th, 2016, 05:51   #408
GaryWagner
TDI(s): Golf Wagon
Yes, I get this as well and have since I installed the springs 8 months ago. An alignment improved vibrations quite a bit, but I still get a hum in the front end at around 70mph when under throttle. Sounds like it originates from the inner CV joint
GaryWagner is offline   Reply With Quote
Old December 19th, 2016, 06:13   #409
tomsyco
How many miles do you have on those CV joints?
Old December 19th, 2016, 07:00   #410
GaryWagner
TDI(s): Golf Wagon
45,000. I think about 5000 miles since the lift and it has not gotten any better or worse.
Old December 20th, 2016, 21:03   #411
Carphuntin_god
I don't know if i ever posted to this thread about it...but i know i pm'd another person here about the perceived hum/thrum, whatever you want to call it when putting load on the system. I don't know how long i've had my lift in...but there was something there. It never got worse (I don't notice it now...so not sure it's even there anymore).
actually, i'll try to work it out... i should be able to figure out when the lift went in vs my fuelly records.
edit... about 18400 mi since lift done
Uber Polluter
Carphuntin_god is offline   Reply With Quote
Old January 6th, 2017, 05:15   #412
tomsyco
I am also getting topping out on speed bumps with the ID parts tiguan 2wd springs in the read with new bilstien TC's.
http://www.idparts.com/bilstein-rear...lf-p-5791.html
Old January 6th, 2017, 05:16   #413
tomsyco
The spring rate seems a little bit high.
Old January 6th, 2017, 05:19   #414
tomsyco
Does anyone have tiguan rear shocks to measure full extension length vs the stock golf shocks?
Old January 16th, 2017, 09:25   #415
tomsyco
To follow up my inner CV joint was bad. Car is great after an axle swap.
Old January 16th, 2017, 09:28   #416
Carphuntin_god
ta da.... anyone imply that the lift caused the problem? or did it just happen? or did the lift maybe just reveal it faster?
Uber Polluter
Old January 16th, 2017, 09:31   #417
tomsyco
I had dislocated that joint ages ago when lowering, so I think I may have caused this issue, because it was present on day 1 after lifting. It wasn't something that developed over time. these springs are a bit too high on the spring rate though and I wish they were a few pounds softer so they wouldn't top out on speed bumps and whatnot.
Old January 16th, 2017, 09:49   #418
Carphuntin_god
interesting. I put in plain str.t front shocks and never hit a topping issue. the Golf-length rear str.t's did top out though...and i put in tiguan rear shocks.
Uber Polluter
Old January 16th, 2017, 09:52   #419
tomsyco
That doesn't cause any issues with over extending the rear? On the front i know the rubber at the joint would probably eventually rip.
Old January 16th, 2017, 12:47   #420
Carphuntin_god
no... it won't over extend... it's just the stock length is a wee too short. tiguans just give a little breathing room.
Uber Polluter
Lift for TDI Sportwagen (for oversize tires) BioDieselLover VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 1 January 25th, 2012 08:37
Resetting for oversize tires. Lightflyer1 OBD Scanners 6 March 24th, 2011 23:36
Do oversize tires cause problems with ABS or ESP? wesmontage VW MKIV-A4 TDIs (VE and PD) 7 August 27th, 2010 21:21
Tires for '09 Sportwagen TDI tdiatlast VW MKV-A5 Golf/Jettas 7 January 27th, 2009 05:55
Any Advantages of Oversize Tires? jaberoo Upgrades (non TDI Engine related) 8 February 19th, 2007 19:39
Page generated in 0.18308 seconds with 11 queries
[Output: 127.79 Kb. compressed to 106.57 Kb. by saving 21.22 Kb. (16.60%)]
