landroverbob
In the mire again but not in the way I prefer - in my lrover.
Last week mateys car failed to re-start after a 6 mile run, dragged it into my garage at home pulled fuel pump relays ( this was last problem I found on a sharan)and swopped for working ones, still no start. pulled pump from tank, cleaned strainer (not blocked but piece of straw?? in the rubber disc valve in the bottom of the pump. checked fuel delivery after filter head and plenty there. re-assembled all. By then was able to borrow code reader Connected it up and lots of dtcs same as list shown below. Then cleared them all tried car and it started ok. tried several startups -all ok, let it get up to temp, all ok, let it cool tried to start -all ok then road tested car- ran fine for three (hard) miles .put back in garage stopped and re-started ok. ten minutes later wont start.Put code reader on and got list below. Tried but wouldn't erase these dtc's.
.17932
17849
19561
18027
17957
Must say totally impressed by this car -when it's running but still prefer my t4 and defender though.
lrb
.17932
17849
19561
18027
17957
lrb
