Turbo Exhaust Manifold Gasket
TDITim83
Ocala, FL
96 Passat Wagon TDI B4V Storm Gray 258k, 98 Jetta TDI 260k (retired for spare parts)
I was just on a 2k trip and my gasket failed between turbo and exhaust manifold. I had and aftermarket one that was just stainless. The Original had metal on the outside and some kind of Carbon or what ever on between the metal. Were do I find this part.....doesn't seem like I can get my hands on it. Any suggestions? I would prefer the Original part compared to this aftermarket considering my issues. I was making a loud noise whistle ish ......so i checked it out and the turbo bolts were loose......Not sure if my torque specs were wrong or if the gasket failed.
ToddA1
NJ 08002
I think that should be metal to metal.... no gasket.
-Todd
Steve Addy
Iowa
97 Mk3
Agree with Todd, I don't remember a gasket for the triangle mounting. There is a gasket between the charger and the exhaust down pipe though.
Steve
TDITim83
Ocala, FL
soo....
I recall removing a gasket from the Exhaust manifold to the turbo inlet....It was triangle shaped with a fiber in the middle and metal on the outsides......it seemed to be a great product......shouldn't have disposed of it. If you removed your turbo you would find out
TDITim83
Ocala, FL
I replaced the gaskets......1/5th was burnt out from the bolts backing out and causing the gasket to get torched out.
