to do the power windows i would assume based on my knowledge you would need the electric window regulator/carrier panels along with the motors, you would need the drivers and passengers door wiring harnesses, and the window switch controls at the drivers door and you need the corresponding door card panels as well (basically everything from a car with electric windows except the actual door and glass).
i replaced my driver door wiring harness due to kinked/cracking wires in various places. its not difficult to strip down the door--> pull off door card panel, pull out the window glass, remove the window carrier panel, remove the door wiring harness which clips in right under where the hood release is. only concern would be if you do plug in the new door harness for the electric windows if it would work?? there are various harness part #'s
if you do gather the parts and would like a hand, PM me and i can help you out
