sfierz
Hey guys, some of you may remember my aborted attempt to remove the intake manifold on my B4. Two pesky allen bolts were the culprit, and I haven't yet revisited that maintenence until the weather gets a little warmer. Plus, I will need a new turbo inlet pipe, too, which is about $130-150. However, this car is just not getting enough air, It runs OK and pretty clean for the most part, but the MAF readings on Vag-com were in the 300 range, not 900 where it is supposed to be. My concern now is that if I remove the intake, could carbon crud drop down into the cylinder head, necessitating removal of the head? That would be bad. In some ways, I am tempted to let a trusted and experienced mechanic do it even though I believe I can handle this job once I get the two stripped bolts out. How likely is it that carbon will get in the cylinder head, and is there any way that can be prevented or taken care of (i.e. shop vac) if it does happen?
