TDI Jim
- Joined
- Jul 10, 2006
- Location
- Gaithersburg, Maryland
- TDI
- 1996 Passat, 1996 Passat Variant (RIP), 2002 Jetta Wagon, 1995 Passat Variant TDI conversion brought back from the dead, 1997 Passat Variant project, and returned 2014 Passat
Starting my conversion of a 1997 Passat VR6 Automatic transmission wagon to a 1Z TDI Manual transmission (from my totaled 1996 Passat wagon, only have engine and transmission left from it). I have all the conversion parts I am aware of from accelerator conversion to drive by wire, to complete wiring harnesses, and finally sourcing clutch pedal assembly today. I will add pictures and information as I go.
First question for the group:
Is the VR6 wagon and TDI wagon tank the same size? If so what changes do I need to make besides the sending unit? I did pull a tdi tank sending tank sending unit out of a TDI sedan, as I was told they are different.
Second question:
Can I use the VR6 gasoline lines from the tank to the engine compartment for the TDI or do I need to change these as well?
Thanks everyone for help with the first of many questions.
Sent from my SM-N910V using Tapatalk
Second question:
