GlacialFlower
ALH oil filter installed upside down
Yes, you read that correctly.
I recently bought a 2002 Golf ALH with 113K. I changed the oil and filter this weekend. After opening up the oil canister I found the filter "TOP" was pointing toward the ground. The filter was jammed on so hard I had to destroy the filter and cut the plastic guts with a dremel cutoff wheel to get it off.
PreChange: The oil light never lit up. I don't know the total miles on this filter. 7K just from me + ???.
PostChange: Clatter goes away almost instantaneously vs. 2-4sec prior to change.
So, now the questions I have for everyone are:
1. How much damage has this possibly done? (Should I do a compression test? or something else?)
2. What can I do to mitigate these effects? (I was told my an old-time mechanic to change the oil filter every 500-1000 miles for a good while to make sure the sludge and debris gets eliminated. Will that really make a difference now?)
3. Would this affect the turbo and its components? If so, what should I check on that system?
This is so disappointing. This guy was a mechanic. Oy...
