dubStrom
- Joined
- Aug 6, 2007
- Location
- Kansas City Missouri
- TDI
- 2003 A4 Jetta (sold), 2010 JSW (sold), 2013 Passat 6MT traded for 2014 JSW with 6MT-TOTALED in November 2016, 2003 ALH 5MT conversion (sold), wheezing 2015 GSW/DSG and a new 2021 Tacoma Access Cab 4x4 p'up
I've searched the site, but haven't found posts with any details on seat wiring connections.
I am swapping out old basic seats for a set of 8way powerseats. Driver seat has memory buttons. I assume that I can't use the memory function without the wiring harness (not in my GLS), but my chassis doesn't even have the power connections for the seats. Powering the seats is my main question here.
Here is the original seat connections. I think that the yellow connector in my hand is the side airbag, Green bus connector is apparently the seat heater connection, and the yellow one next to it is definitely the seat belt connect detector. Can anyone confirm these?
The high end memory seat (memory on drivers side only) has two additional connections. I am not showing the passenger seat, which has the red bus connector for power seat power connection but no tan connector. The tan one is driver only, so I think that must be for seat memory (settings stored in the comfort module or another remote place under the dash?):
So here is my question... I just want to power the seat so the adjustment controls work, but there are three tabs inside the red connector for spade connectors. I think one needs the 15amp 12V power, and one of the others needs ground...NONE are grounded to the electric motor bodies or seat frame by multimeter test (?). Which one is the 12V input, and which is ground? I can test with a 12V source with spade connectors (I do not have the harness from the donor car). But I should be able to at least get the seat powered. 1 and 3 are wide, and 2 is a narrow connector... Any clues appreciated???
[/url]
