Hey!
02q transmission (JLU transmission code).
SMF does work fine, however I have begun to hate (after 5 years) pressing the clutch pedal at a standstill due to the transmission making loud noises.
When I used the CM FX350 kit, the transmission noises on idle were there, but I increased the idle RPM to 950RPM and the noises disappeared.
Now with a CM FX100 kit the idle noises disappear at around 1300RPM at idle...
The Fluidampr didn't do much in regards to absorbing noises..just taking vibrations off the crank.
you need a heavier flywheel
no practical way around it
you could reduce the compression ratio and retard the injection timing but that really isn't an ideal solution
what it is is the backlash of the gears snapping back and forth,
as the engine comes up on each compression stroke the crankshaft slows down a lot, so the idle gears snap into contact on the coast side of their teeth, then shortly thereafter the power stroke speeds the crankshaft back up again, snapping the gears back against the drive side of their teeth. Keep in mind this is only two "snap" noises, this pattern repeats itself twice per crank revolution, making that horrific growl.
This thought in mind, it is easy to see what a DMF is doing; isolating the massive shock load of the engine from the gears of the transmission through a soft coupling to a second flywheel mass.
More rotating mass will dampen these changes in crankshaft velocity just as surely, and in a much less failure prone manner.
