I was able to warm up the bags in hot water and slide them into the coil springs fairly easily. I read and re-read and then re-read Airlift's instructions:
Air inlet nipple goes up.
When I'm threading the bags in, I'm looking at the top bump stop/spring seat for the coil springs. I'm thinking no way these flimsy feed line is gonna pass air once the weight of the vehicle is on the spring. I say to myself, "Self, keep it down, these are smart folks who have been doing these installs a very long time and must know what they're doing."
Doggone it all, I should have listen to myself!!!!
Once the weight of the vehicle is on the springs, I can't get air in or out of the system. I'm really pretty irritated with Airlift right now, their directions stink and now I'm gonna have to wrestle with them airbags expanded in the coil springs AGAIN.
I'm thinking I need a hard plastic or steel L-shaped fitting to get routed out past the spring seat/bump stop in order to be able to raise and lower the vehicle without jacking it up ever time.
What do y'all think? tia...
