TDPotvin
Purchased used in 2012 and have had great experience so far! Have been trying to clear a glow plug heater circuit fault. I have replaced the glow plugs, glow plug wiring harness, and glow plug relay. I purchased the VAG-COM program and found some other problems which do not show up with just a regular code reader. These are what I currently have listed from the VAG-COM:
Address 01: Engine
2 Faults Found:
16764 - Glow Plug/Heater (Q6) Circuit
P0380 - 35-10 - Malfunction - Intermittent
17964 - Charge Pressure Control
P1556 - 35-10 - Negative Deviation - Intermittent
Address 15: Airbags
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments
1 Fault Found:
01039 - Coolant Temperature Sensor (G2)
30-10 - Open or Short to Plus - Intermittent
Address 46: Central Conv.
4 Faults Found:
01329 - Convenience System Data Bus in Emergency Mode
35-10 - - - Intermittent
01331 - Door Control Module; Driver Side (J386)
49-10 - No Communications - Intermittent
01179 - Incorrect Key Programming
35-00 - -
00944 - Heated Exterior Mirror; Passenger Side (Z5)
35-00 - -
My question at this point could this be a computer problem? I had 2 problems I was trying to fix I did have a problem with the antilock braking system I did a full break job replacing rotors, calipers, pads, all sensors, fluid flush. That code is cleared and antilock braking system working perfect. I have looked into replacing the engine control module, but if I understand that needs to be programed to the vehicle. I have only used the VAG-COM to scan, not to make any changes. I had some suspicion about the vehicle when I purchased so had the police run Vin. check came back clean. I tried purchasing a spare key from VW dealer, when it came in it would not turn in the lock or the ignition. Any input would be greatly appreciated!
Tim
Address 01: Engine
2 Faults Found:
Address 15: Airbags
1 Fault Found:
1 Fault Found:
4 Faults Found:
35-00 - -
35-00 - -
Tim
