I live in Northern Ontario and I'm freezing in my TDI. I have a 2004 TDI Bora that won't heat up unless you drive it really hard for a long distance.
I know diesel vehicles do not heat unless you drive them because they are so efficient, but I can't drive my TDI with frosted windows to warm the car up.
I have installed an inline block heater, which helps, but there are tons of places I can't plug my car into so that only works sometimes. I have even blocked the entire radiator off to prevent cold air from getting near it.
Has anyone ever wired an auxiliary heater into their TDI? I know you can buy ones that plug into a cigarette lighter but then don't give off any heat. I want to wire a powerful heater in the vehicle that I can use until the engine reaches a hot temperature.
Anyone have any suggestions?
FYI
-Today was –24C (-11F). Even after driving 22km the engine never reached 90C
-I have had the thermostat replaced last week, still no better.
-Engine coolant is fine
-Even with the rad blocked off the vehicle barley gets to 90C.
FYI
