Cheap guy
Hello, How is everyone? This group was boasted about to me by a friend, so I'm new here. You can call me poorbadluckbuck.
So after a bad back injury I find myself on odsp not by choice. Which means I have no money. I only need a vehicle so I can get my daughter who's an hour away for our visits. I've gone through a truck, my Audi, and a VW over the last eight years s of driving both ways.
I know .. wa wa. Such is life. My point being is I managed to get a car after my 2000 VW finally dies at 600 000km. 850 km per tank of fuel.
My new car. 2003 VW wagon TDI.
Got a deal... Ya ya, turns out it needed a new engine. Ha ha, jokes on me. ... So I did an engine swap.... Yes I owe people money. ....
When I swapped the 1.9 TDI out I took the EGR delete pipe and over sized air filter off my old 1.9 and put on my new one. While doing all this work. It seemed a good idea to delete the EGR cooler as well. Don't need it, take it off. Right?..... Then I deleted the codes with a scanner.
Here's my problem. I can't keep it out of limp mode. The fuel economy is killing me. 700 instead of 950 plus...
I've since changed the fuel filter, as a code said infificient fuel.... That code is gone.....
It seems to fall into limp mode as soon as the car starts to heat up....
New car, new moter, I don't know what sensors to check or where to start.... I thought maybe I screwed up the vacuum lines, but they checked ok..
Does anyone have any suggestions?
Thank You
Thank You
