Blackjedi
- Joined
- Aug 15, 2014
- Location
- NE corner of WA state (Kettle Falls)
- TDI
- 2000 jetta 5 speed 1.9 alh tdi
Hey guys, I have been battling this issue for a few months and no matter how much I search I can't figure out what it is. I really can't afford to throw money at my 2000 jetta tdi as it is the reason I got it, to save money on fuel. So I would like to fix on the first try. Anyway this issue started when it got warm out. It has normal boost and runs good when the motor is cool or if it is below 60 degrees outside. If it is above 60 it will run and pull good untill the motor has been at full operating temp for approx 15 minutes, then performance is considerably weaker although it still drives well, it's when the outside air temp is above 70 when it starts getting weak and it will throw it into limp mode if you step on it. When it is above 80s its no fun to drive, 90s it's a real turd, 100s it's a bigger turd. Cel periodically comes on for a code 17964 control pressure regulation limit not reached. It will throw this code sometimes on start up, and sometimes when thrown into limp mode. Sometimes the cel won't come on even when thrown into limp mode and sometimes the cel will be there on start up and then go away when driving... I find this very strange, any tips for things I should check or do?! Any help would be greatly appreciated
