blizzak
Hey guys,
My MK3 with PP520's, RC2, EGR delete and an overboosting turbo might be experiencing a slipping clutch. Just hoping you could all give me some advice about it. For starters, I discovered the clutch was changed by a local trustworthy dealership, (AFAIK, are any of them really...) at 217,000 km in July 2003. I bought the car with 260,000 km on it and it's now just over 320,000 km. EGR has been deleted for 27k, RC2 has been on for about 10k, PP520's for 7K, IQ currently at 3.4. I recently had a split intake hose which I just recently fixed, car had reduced power and increased smoke for probably 500-1000 km. I was pretty sensitive to the smoke and didn't let my right foot go down too far, but my girlfriend took the car for a day and smoked a lot of people unknowingly . Could this have caused damage?
I replaced the split intake hose but had a fair bit of oil spray under the hood for the time it was leaking (see pics here). I know people have said that any oil on the surface of a clutch disk pretty much means you'll be replacing it, but I don't see any possibility that oil or anything else got in there. Bell housing plug was in and that oil was nowhere in the vicinity anyways. I drove the car after replacing the split hose on Saturday and power was back. Got on it in 3rd gear around 3000 rpm and clutch started slipping! Either that or I spun the tires and didn't notice it, but I don't see that being likely. Yesterday I drove it pretty carefully just around town and didn't feel any slippage.
So, given that the clutch is (only) 100,000 km old, does this sound like normal behaviour given my relatively recent power mods? I know the MK3 clutches are supposed to be better than the MK4 clutches, is this only because of the lack of DMF? If I just be sure to not let it slip, should I be okay for a while? I'd be open to any suggestions as to further tests to determine how bad it really is, but I've taken it easy since it first slipped. Saturday was the first time I ever experienced it slip. I guess it will eventually need replacing, but I really want like a DC stage 3 or 4 down the line so was hoping I could save for a bit and maybe put this off with some carefulness. In the meantime, I could put the stock chips back in too.
Thanks in advance for any advice y'all can give me.
