vixentd
Have a 1997 and a 1996 B4V. The 1996 has more vibration at idle. I have checked the part number and on the front motor mount on both vehicles and it is the same. The 1996 motor mount appears good as it does not move excessively when you let the clutch out and keep the brake on. In the past on VW diesels usually when the mount goes the motor moves excessively when you do that.
1. Is it possible the front motor mount could be gone still? I have considered swapping front engine mounts but before that thought I would consult the experts.
2, is there another mount that could be causing this?
3. Anything else to check for vibration.
