AC and front radiator cooling fans not working
chdeason
Tennessee
2011 TDI Sportwagen
2011 TDI Sportwagen. Relatively new compressor (about a year) but not cooling, but blower works. The fans in front for cooling radiator don't work either. Seems like a fan control module problem from what I read about earlier models but can't find anything on this version of the car. FCM was below the battery on earlier models. Anyone have any insight or experience with this? Thanks.
oilhammer
outside St Louis, MO
Avail yourself of that car's OBD. It works. You may have dead fans. You may have a bad pressure sensor. All of this, and much, much more, can be accessed via that wonderful DLC. :)
The control module is integral with the left cooling fan, fwiw.
blackcloud08
CND
2011 JSW
Will the fan control module being bad still allow the the fans to work when the car regens? My a/c only blows cold on the highway then dies at slow speeds. RCV, expansion valve were just replaced and recharged. My fans don't come on when I turn the a/c on.
oilhammer
Scan tool ---> DLC ---> Climate ----> Measuring Blocks ---> refrigerant pressure. Not enough pressure means the fans won't come on.
blackcloud08
CND
2011 JSW
Forgot to mention that the shop hooked it up and said all the compressor values/pressures are in spec.. He didn't have the wiring schematics for the fan so he didn't want to mess with it. Just wondered if there was some type of switch/control that would prevent the fans from coming on since the pressures were correct.
oilhammer
There is the refrigerant pressure sensor. That's it. G65. Three wires. 12v, ground, and signal back to the Climate module. The Climate then tells the Fan module how fast to run. You can see this data with a scan tool. It is pretty simple.
blackcloud08
CND
2011 JSW
Picked the car up tonight and the guy went ahead and changed the refrigerant pressure sensor and the fans now come on with all 4 settings. Air is much cooler but I'm going to buy the vcds so I can check everything. Is Ross-Tech the best place to get it from? If we have a forum vendor that sells them I didn't see them.
