jimmy0000
Hi All,
I have 2003 TDI, 274k miles, 5spd manual, there is no check engine light.
I have weird low power issue where sometimes when i start the car it might be at 25% power, barley able to idle, or run just fine.
If the engine power is low i will just pull over turn it off wait 5 seconds, turn the key on until the glow plug light goes off it normally then runs fine.
Recently its been happening more and more.
Any troubleshooting suggestions or info would be helpful.
Thank you
Thank you
