BBB129
- Joined
- Feb 25, 2014
- Location
- Scottsdale, AZ
- TDI
- 2005 Passat Wagon BHW 2004 Jetta 5 spd BEW - 99.5 jetta 5 speed - 1982 Mercedes 300D Manual 4 spd
I have a Frantz low pressure oil filter kit, you just use a roll of TP and it filters in addition to Stock filter set up, I imagine on my B5 it would be a bad idea and filter out some of the needed additives for the cam.... I will probably just be installing it on my 7.3L but i'm curious as to peoples thoughts on it for the BHW I originally pulled it off an ALH TDI..... I'm also still unsure about using T6 although i've read plenty of happy people....can't seem to easily find/understand lab test results on the forum here for T6...honestly not spending a lot of time searching it at the moment, im tired of getting distracted and reading about things I probably shouldn't be
