Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > VW MKVI-A6 Jetta Sedan (~ 2011+)
VW MKVI-A6 Jetta Sedan (~ 2011+) Discussions area for the MkVI (2011+) Jetta sedan. This model was originally codenamed NCS (New Compact Sedan).
Old November 19th, 2014, 18:48   #1
dirtysouthjacket
dirtysouthjacket's Avatar
Default ***MkVI Jetta Sedan Specific DIY/FAQ/HOW-TOs Smorgasbord***
I've been slowly bookmarking threads over the past two years of owning my MKVI Jetta Sedan. I'm pretty forgetful and got sick of searching for threads over and over. Surprisingly, there still isn't a real FAQ thread specific to the MKVI Jetta Sedan.
So here are all the links that I've been hoarding in a spreadsheet.
Disclaimers:
1. I wanted links to be as specific to the Jetta Sedan as possible, in some cases there are links that are for other platforms, but still apply.
2. I tried to use TDIClub links as much possible.
3. None of these are in any sort of order.
4. Some of the links are pretty old, if you have better ones please let me know.
Basic Info for TDI Newbies
How To Search TDIClub
How to Post Pictures
VCDS/VAG-COM User List
TDI Guru List By State
General Info for MKVI Jetta Sedan
2011-2015 MKVI Jetta Sedan Info
VW's CR (Common Rail) Self Study Guide (OEM Info On Your Engine) - This link is actually pretty interesting...
CR Injector Info
Used MKVI Jetta Buying Guide (What to Look For) - Don't think I've seen one of these yet...
My Glow Plug Light is Flashing, What does it mean?
How To Reset Your MFD Service Icon (Wrench)
Reset TMPS Icon - For the record, not a true TPMS sensor, actually just uses ABS sensors to detect tire pressure
All MKVI Fuse Diagram - Updated thanks to "CDN TDI", Please Notify if yours is different
1,000 Miles on a Tank
Major Known Issues
Winter Icing - Hard Start - Water in Intercooler - etc
HPFP (High Pressure Fuel Pump) Failure FAQ
Jerky DSG
Turbo Failures - No specific link yet
Cracked DPF - Also no good link yet
2012 Jetta TDI Premium; Dual Horn, Hybrid Grill, bunch of sound deadening to install
2004 Jetta TDI GLS - SOLD
1991 Mastercraft ProStar 190
2011 BMW F800GS, 2003 Kawasaki Super Sherpa, 1997 Kawasaki KDX200
dirtysouthjacket is offline   Reply With Quote
Old November 19th, 2014, 18:48   #2
dirtysouthjacket
Maintenance Info
Official VW Maintenance Intervals
2011-2014 Oil Change How-To (DRAIN)
2011-2014 Oil Change How-To (EXTRACTION)
2015- EA288 Engine Oil Change - NEW
Fuel Filter Change How-To
Fuel Filter Change with VCDS Priming How-To
Air Filter Change How-To
Cabin/Pollen Filter Change How-To
Jack Points on MK5/6
Timing Belt Change How-To
DSG Filter and Fluid Change How-To All my TDI's have been manual, so please let me know if there is a more specific thread
DSG Filter Change #2 - NEW
Brake Service and Flush - Could use a more direct link here
ABS Sensor Cleaning/Removal How-To
Head Light Aiming How-To
Exterior Bulb List
Headlight Bulb Discussion - NEW
Disassembly/Repair
Turbo Removal
Turbo VNT Repair/Replacement for MKV - Similar for MKVI
Cheap Wiper Blade Replacements - NEW
Known Fixes
Frozen Windshield Wiper Fluid/Motor
Blown Windshield Wiper Motor Fuse
Sticking HVAC Buttons
Replace HVAC Fan Motor and Resistor
Squeak/Rattle Fix Thread 1
AC Not Working or Not Always Cold? Check your RCV (Refrigerant Control Valve)
Squeak/Rattle Fix Thread 2
No Sound from Radio/Blank Screen
No Sound from Radio Thread 2
Door Lock Not Working, Door Lock Module Rebuild - NEW
Misc Info
ElectroMechanical (Servo) Steering Rack Info
Old November 19th, 2014, 18:49   #3
dirtysouthjacket
Performance Upgrades
DPF Delete
ECU Tunes
DieselGeek Short Shifter
Intake Flapper Valve Info
Stage 3 CR170 Turbo Upgrade - This Turbo is stock on most European CR TDIs
Clutch Life with a Tune Info - NEW
Suspension Upgrades
Suspension Info and Lowering from VWVortex
Independent Rear Suspension Swap from MK5/6
Air Suspension Info from VWVortex
Old November 19th, 2014, 18:50   #4
dirtysouthjacket
Interior Upgrades
Always On 12V Outlet How-To
Adding an Underseat Drawer How-To
Adding Sub/Amplifier using Stock Radio
Interior Panels and Trim Removal How-To
Bluetooth Microphone Quality Improvement
Overhead Console Swap to Add Sunglasses Holder How-To
Adding Puddle Lights to Doors How-To
Sound Deadening MKVI Jetta
Adding Homelink Rear View Mirror How-To
Auto Headlights How-To
Adding MFD to Steering Wheel
Another Adding MFSW Thread
Where to Mount a Scangauge
Sliding/Adjustable Center Arm Rest Swap
Adding a Garage Door Opener Switch to Button Row
Traction Control Button Install How-To
Adding Rear Passenger AC Vents
Adding LED Lights to Cup Holders
Exterior Upgrades
Increase Fuel Tank Capacity by 1.5+ Gallons
Adding Front Fog Lights for Cheap
Curt Tow Hitch Install How-To
Wheel Fitment and Offsets
Adding a Back Up Camera to Nav Unit How-To
Faster Warm Up Time with Jetta Hybrid Front Grill
Dual Horn Install - Even Newer!
Brighter Reverse Bulbs
Old November 19th, 2014, 18:52   #5
dirtysouthjacket
TDI Dictionary!
6MT = 6 Speed Manual Transmission
DSG = Direct-Shift Transmission
CEL = Check Engine Light
CR = Common Rail, fuel injection style of the MK5/6 engine
DPF = Diesel Particulate Filter, an ash filter in the exhaust
EGR = Exhaust Gas Recirculation, an engine emissions device
HPFP = High Pressure Fuel Pump, the MK6 has 3 fuel pumps, the HPFP being the last before the injectors
IMHO = In My Honest Opinion
IRS = Independent Rear Suspension
PD = Pumpe Duese (Another name for engine type in MKIV BEW Jetta/Golfs)
PM = Private Message, check your messages!
TDI = Turbocharged Direct Injection
VCDS or VAGCOM = Product sold by RossTech for interfacing with VW ECU's through OBDII
YMMV = Your Mileage May Vary, easy way of adding a disclaimer to a statement
Here is some topics I could use some help with!
Help with Fuse Diagrams - The most current known fuse diagram for MK6 Jetta TDI is linked, however I'm not convinced it is the same for all trim levels and DSG, please compare to your car and let me know if you see discrepancies. Its criminal that there isn't a fuse diagram from VW.
Used Car Buying List
Advance TDI Member Maintenance Intervals - Engine Specific, DPF, intake flapper, suspension refresh, engine mounts, oil pump, turbo inspection, fuel pumps, etc....
DSG Service How To Link
Turbo Failures - Lots of threads about failures, but nothing really summarizing it... Specifically talking about regens/high EGTs being the likely cause
Anyways, what am I missing? I know there is a ton more good stuff buried in the archives!!!
Old November 19th, 2014, 21:50   #6
torrimac
Here is a drive link to the fuse panel.. should be for the 2011 version.
https://drive.google.com/file/d/0B4U...ew?usp=sharing
And, I notice you have this in there already.
Great list though. I have it bookmarked and ready for when i mess something up. much better than the 400 others i have scattered all over.
torrimac is offline   Reply With Quote
Old November 20th, 2014, 08:17   #7
Victor Ward
Victor Ward's Avatar
Can we "sticky" this?
Awesome info here, thanks to putting it all together.
"The better you look, the more you see".
Last edited by Victor Ward; November 20th, 2014 at 08:34. Reason: To say thank you.
Victor Ward is offline   Reply With Quote
Old November 20th, 2014, 12:39   #8
Black_Smoke
Black_Smoke's Avatar
Fuel Economy: ~4.9 l/100km. Could be better if I drove slower.
Good stuff.
Thanks!
Nobody likes spark plugs anyway.
Black_Smoke is offline   Reply With Quote
Old November 20th, 2014, 15:37   #9
dirtysouthjacket
Thanks! I can't take any credit for the material, I just thought it would be nice to have it organized and in one place.
Old November 20th, 2014, 18:32   #10
lance2214
Thank you!!
I too, kept searching all over the place and websites definitely sticky material!
lance2214 is offline   Reply With Quote
Old November 21st, 2014, 09:34   #11
Good Ol' Boy
VeeDubTDI's Avatar
Boom!
Great thread, by the way.
Old November 21st, 2014, 19:04   #12
dirtysouthjacket
No Problemo! And thanks for all the kind words. Just trying to do my part to give back to such a wonderful community. I don't know how I would have gotten through my timing belt break on my '04 back in 2010 as well as stripping out its 5th gear, without Fred's.
So some other ideas I was thinking of.. I think the last post up there, I am going to make a short FAQ section, as well as a definitions section. A lot of acronyms are thrown around on here and it can be a little overwhelming for new people. Also, any new threads or updates, I will call out respectively.
Old November 24th, 2014, 08:49   #13
bennybmn
There was a thread a while back I'm looking for now, maybe you guys can help. Issues people have had with their keyless entry and start not working. I seem to remember one of them showing something you can reset to make it work better....
____________________________________________
Euro Switch, Dual horns and powder coated Portos so far... TC off switch soon!
bennybmn is offline   Reply With Quote
Old November 25th, 2014, 12:10   #14
bennybmn
Found it... I actually started it :O There wasn't a lot of actual how-to in it, just things to try, mainly changing the fob battery. Which I did last night... and it worked.
Old December 5th, 2014, 21:08   #15
torrimac
I just found this while looking for where the sensors where actually located. Maybe someone can bring it over here? VWvortex link about Cleaning ABS sensors, could also be used to remove/replace them I suppose. It does have a nice little tid bit about how they need no adjustment.
http://forums.vwvortex.com/showthrea...g-(In-10-steps)
MkV (05.5 - '10) Jetta FAQ/DIY kromicacid VW MKV-A5 Golf/Jettas 17 December 19th, 2017 10:43
FAQ: 2009 - 2010 TDI-specific issues DoctorDawg VW MKV-A5 Golf/Jettas 240 February 2nd, 2017 15:56
MkVI DIY/FAQ - Start here dzcad90 VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 19 December 10th, 2015 08:26
Mudflaps for Jetta MKVI Sedan BarrieCommuter VW MKVI-A6 Jetta Sedan (~ 2011+) 3 November 18th, 2010 15:30
'05.5-'06.5 Jetta FAQ/DIY eluwak VW MKV-A5 Golf/Jettas 33 October 14th, 2009 16:29
Page generated in 0.20033 seconds with 11 queries
[Output: 144.61 Kb. compressed to 121.63 Kb. by saving 22.97 Kb. (15.89%)]
