rosskuhns
SOLD to germerican, thanks for all the other inquiries.
I sold my ALH and just cleaning out the garage forgot I had this. Brand new, never installed. It has the IDparts install kit with it too, and directions I printed out back when. It also has a bypass added so that (IIRC) the pump dies, you can still pull fuel.
https://www.idparts.com/pd-in-tank-lift-pump-a4-bew-p-585.html
They're $230 for the pump, and $130 for the install kit, so $460.
Send me $200 via paypal and it's your shipped. Garage cleaning special. I can email pictures if you need them.
This was the next upgrade for my TDI I was going to do, the common refrain was, with the lift pump, the engine will keep pulling strong in higher rpm's, whereas mine was running out of breath.
cut from IDparts.com-------------------------------------------------------
Great Upgrade for ALH/AHU/1Z Cars
Adding a lift pump to VE engine cars takes work away from the rotary pump since fuel is provided under low pressure (5-8 PSI) to the injection pump whenever the ignition is on. This helps cold starting, makes the engine run smoother at low speeds, and provides more fuel at high load, especially helpful in modified cars. Installation requires custom wiring with a relay and power source. These items are available below in the install kit. The pump will fit in the tank of Mk4 and Mk3 cars, although the Mk3 may require some work to make sure the fuel gauge reads accurately.
