luke.weiser
Hello. The speedometer on my Jetta suddenly stopped working. Was scooting along at a decent speed when it happened: it just started jumping around until it finally stopped at zero.
Both the speedometer and the odometer do not work.
This led me to think the sender went out. Replaced it with a new part, which did not fix the issue.
What do you guys think?
I know that the Mk3 chassis is well known for having some quirky electrical issues. Is there some way to test the wires that plug into the sender, or should I just assume the cluster is bad and replace it? Car has 140k on it.
