hpglow
Ahhhh yeh....
My stuff just came in the mail.
That's not the 20 manifold.17 or 20?
I really didn't need to know that.hpglow said:My stuff just came in the mail.
Ok, what will you do for the lower charge air hose to the IC?hpglow said:Ahhhh yeh....
It has to be unbolted and rotated. Yes the output looks to be 2". Everything was included gaskets seals nuts bolts, and a billet alum piece to adapt it to my stock IC. If you need I can take a pic of all the little hardware that goes with it.LurkerMike said:Ok, what will you do for the lower charge air hose to the IC?
Is that included?
The compressor is obviously rotated 90* from stock and the
90* section is molded into housing. Is the output nipple 2" OD?
bow chica bow bow = This defines the sound of the music track in a porno film as things are heating up.DPM said:Bowchickawawa
Yes! If you don't mind...hpglow said:It has to be unbolted and rotated. Yes the output looks to be 2". Everything was included gaskets seals nuts bolts, and a billet alum piece to adapt it to my stock IC. If you need I can take a pic of all the little hardware that goes with it.
huh?Souzafone said:Disgusting what some people will do. I hope you enjoy your "toys".
LurkerMike said:Yes! If you don't mind...
I was torn about which KERMA turbo to order so I settled for the SS17 for plug and play simplicity.
But I will eventually move the SS17 to Whitey and go with either a straight KERMA 17 or a KERMA hybrid for RED.
It would be nice to make any needed changes to my lower pipe design now, before I am locked into a production run, to accommodate this style compressor outlet. I would like the coupling from this style outlet to my 2" pipe to be as straight and and as l-o-n-g as possible (to absorb engine vibration and movement).
It would suck to find out that my lower pipe would not work easily with that outlet style when a slight pre-production change would have solved the issue.
Do you have access to a steel welder? Would you be interested in checking a steel lower pipe prototype for fitment if I sent one to you?
What your looking at is a Q-Loader from kerma that allows remote chip tuning, a set of Power Plus Nozzles that will feed more fuel to the engine, and a Vnt-17 from the PD-150 that will allow me to do this without smoking. And why is it good well your looking at any where from 40 to 80 extra hp.Lightflyer1 said:For those of us not so knowledgeable, what exactly am I looking at and why is it good?
Viagra!!Lightflyer1 said:For those of us not so knowledgeable, what exactly am I looking at and why is it good?
I get that allot, it's not you, its me...hpglow said:Ok I think I didn't fully understand what you were asking in the previous post.
Gotcha!hpglow said:But here it goes you have to rotate the compressor housing so that it is facing down.
NOOOOOOO!!!!!hpglow said:Then you have to cut the last 90 degree turn off the factory rubber pipe.
No need to mess with the adapter... I would just need you to remove the lower pipe and hose, and install just my pipe (a steel prototype version). See if it needs some adjusting to get it aimed straight at the turbo outlet. If it does, hack it with a hack saw and just tack weld it the way it needs to be. Then mail it back to me.hpglow said:I have access to a wire feed welder of some sort, well my dad has one to be more specific but I can't say what kind it is as I have never used it. But with enough beer I'm sure I could convince him to do it for me. I may be interested in trying out your part but the problem is that I would have to get that adapter out of my turbo or your pipe would have to fit on the adapter at this point. So you would have to give me a couple weeks to a month(hey I work a full time job) to beat it in there.
KERMA's turbo's or my pipes?Lightflyer1 said:And now the light comes on! I have been reading of these things but never actually have seen any of them.
i dont wanna brag about myself but here in canada its not 21 years old its 18 years old so we can see ASS .... hee i wanna say kickASS turbo . before you guys.brucetmoose said:NY has it on their books that you have to be 21 to get that kind of porn in the mail. God forbid some whiz kid in high school invents the 80 MPG diesel !!!
Swaintech does nice work03_01_TDI said:Now what sexy is
a nice ceramic coating on the manifold
