Key Fob Programming W/ VCDS
skyblaster
British Columbia, Canada
2013 GSW Highline
For a 2013 MK6 Sportwagen, should I be looking for a TP23 or TP24 ID48 chip?
I was only provided with one key FOB (5K0837202AE, 5FA010180-22 Hella 315MHz, FCC: NBG010180T) with my car and looking to purchase another FOB as well as a regular key from AliExpress.
jokila
Houston, Texas
2003 Jetta GLS, Manual
Sometimes you can toggle that electrical switch on the door by pressing unlock twice and then lock to activate all the door locks. Ideally replacing the module in the door is the ultimate solution but arguably the toughest thing you will ever attempt at doing. More people own FOBs from that issue alone than any other reason.
That would be probably due to a faulty door lock module not knowing the door is open allowing the doors to look. That is not normal behavior.
What I described is the way you can lock all doors while on the outside of the car.
