Caddyrage
I've been having problems with starting my caddy 2k 1.9tdi bls engine when cold or hot.
Glow plug 3 comes up on vagcom as being open.
I'vefollowed the procedure in the tdi 101 section to test a few things.
Glow plugs all read 2.4 using multimeter using ground where the battery connects and the positive on the tips of the plugs.
I then disconnected the coolant sensor to the right of the engine which kick starts the fans when ignition on.
I tested the glow plug wiring loom and only reading approx 2.60 across the 4 which all drop to 0.16
Does this sound like the relay?
Torsion value is set at 0.5
I've watched the rpm on vagcom when cranking and it's good, 290+ as I've read the injectors don't work below 250
Any ideas people ?
Any ideas people ?
