beanboy33
i have an 03 Jetta wagon. My high beams stopped working. The driving lights and low beams are fine. When i turn on the high beams by pushing the lever away from me, all the headlights are off. When i pull the lever towards me, the low beams stay on and no change is noticed. The high beam indicator is working. I have no problem with the cruse control or the turn signals. I removed the steering wheel to and bottom covers so i could spaying contact cleaner in there. No help. I checked the fuses, they are OK. still haven't checked the bulbs. It would be kinda strange that they both were to blow at the same time. is there a relay or something i should check? or if the bulbs are good just buy a replacement switch assembly?
