BRM turbo adjustment
I would start off by gathering tools:
- safety glasses since you are working directly over your eyes, and looking up.
- a 3 mm internal hex (allen) bit, the longer the better
- a 10 mm deepwell thin wall 1/4" drve socket. You may need to thin the wall further, in order to fit around the 10 mm lock nut without being held off by the oil drain flange.
- all the 1/4" drive extensions you own, 24" total is not too much.
- a 1/4" wobble extension.
- VCDS (optional but highly recommended - otherwise you are making blind adjustments.)
- mityvac hand vacuum pump or equivalent, with hoses to fit turbo actuator (3mm ID, I think.)
Some folks have had to remove the bolts from the oil drain flange or even remove the oil drain line completely to access the set screw and lock nut; some have not.
you must have your turbo oil drain line installed to run the engine.
Next know the risks of what you are about to do. You are making adjustments on a limit switch stop set screw that should be made at the factory. You are never supposed to adjust this. Adjusting this negates your warranty.
Another risk is that at least 3 people that I know of have broken off the limit stop mounting flange on the early BRM turbos when they went to make this adjustment. They were all competent wrenches; this can happen to you as well. Two shops replaced the turbos. One owner fabricated his own stop screw mount that mounted on the turbo drain line and flange. In any case this will ruin your day completely.
Captions are below the photos.
View as if from the top of the engine. Oil supply and air lines removed.
View as if from the bottom of the engine, oil drain line removed. Lock nut and setscrew visible on the engine side of the oil drain flange.
View from the top and car left (maybe 7 feet tall standing near the air filter housing, sort of as if you could see through the head
This is a view you would really love to have, but it is looking aft, and you would have to look through the head to see this. Down is to the left in this photo. A long hex bit has been inserted into the set screw. In this view you can also see the two lock nuts that adjust the turbo actuator motor locking nuts - the ones you have to move to set initial movement vacuum to 5" Hg.
it is easy to unlock and adust on the bench. You wish you could do this on the car. Note that the oil drain line flange interferes a lot. Very thinwall 10 mm socket or crowsfoot required to unlock the nut. The set screw is 3mm internal hex.
Highly recommended - adjust the turbo cracking pressure to 5" hg mercury before proceeding further.
Optional but recommended: Start the car and do basic settings test 011, charge control, with a vacuum gauge teed into the actuator line so you can read the vacuum levels. Log the max and min readings of vacuum and charge. Some ECUs will let you see turbo position while doing this; if you can log the turbo max and min positions as well.
1)Start up VCDS, read measured value block 43 field 2 with no vacuum and note the turbo reading - it should be 0%, more or less. Set the computer next to you under the car, where you can read it.
2) Now apply 24" hg vacuum to your turbo actuator. Note MVB 43-2 again. It should be near 100%. Leave the vacuum applied.
3) Reach up with your 10 MM thinwall socket and unlock the locknut. You may have to grind the socket wall thinner. Just get it broken loose; don't go turning it.
4) Now reach up with your 3mm hex bit, insert it into the set screw, now spin the locknut off about 2 turns, then turn the set screw in about 1 turn. I turned mine in 1.5 turns, and changed the setting from 100% to 92%.
5) Note the VCDS reading. While holding the set screw in position, spin the lock nut up snug with your fingertips.
6) Tighten the locknut. 11 ft lbs should be enough. This is little girly forces, not manly man forces.
7) Ensure the VCDS reading is what you intend.
8) Start the car, hook up your turbo actuator to its normal line (tee in your vacuum gauge if you can) and do basic settings test 011, charge control. Ensure you still have at least 80 mbar difference between the max and min mbar readings. I would say 80 is the absolute minimum, not the target (different than other more knowledgeable folks suggest) 150 to 200 is probably ok, anything over 200 may mean you want to adjust the set screw in some more. On some ECUs doing this test may reset or adjust the postion percent reading. I noticed on mine that after doing this test my turbo position at full vacuum read about 100% again - and I do not think the set screw moved.
9) Go for a test drive. See if your excessive lag, lots of smoke problem has been solved. Adjust again if needed.
I wish it was as easily done as it reads.
Good luck.
Remember, I warned you that you do this at your own risk.
