Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Atlantic Canada
Atlantic Canada Atlantic Canada Section. This section is for people in Atlantic Canada to discuss items more local to them.
Old August 26th, 2006, 15:28   #1
Bmarc
Bmarc's Avatar
TDI(s): 2000 Jetta
Default Parts List
We were talking last night about making a list of parts and such that people are either looking for or think would be good for having as spares kicking around. Check out Brians site:
http://www3.ns.sympatico.ca/roseland/VWPartsA4.htm
We can start putting a list together and I can pick up the parts from him as I only like ~20 mins from him.
One thing is sway bar bushings, I know at least mine are in bad shape and can only assume a few others are in the same boat. Duane also said he needed an upper strut mount bearing. Is anyone else in this boat?
So lets get this going if anyones intrested.
*DEAD* 2000 Jetta TDI equipped w/ .205's, Blistein TC shocks and struts, Eibach Proline springs and a stubby antenna SLOW and LOW
2000 Jetta VR6
Bmarc is offline   Reply With Quote
Old August 26th, 2006, 18:04   #2
sportsguy
Yep - one upper strut bearing-thingie for me.
Best throw on a fuel filter and air filter for me, too - been about 50,000 since I last swapped both.
I'd go for a tie-rod, too, but I'll leave that with the dealer to swap & get an alignment at the same time.
2014 VW Beetle TDI DSG :: 2012 Yamaha Super Tenere :: 2012 KTM 690 Enduro R :: 2011 Toyota Tacoma :: 2003 BMW Z4 3.0i
sportsguy is offline   Reply With Quote
Old August 26th, 2006, 18:43   #3
Fyrman
Fyrman's Avatar
Default Official List. Add your name and desires!
Lets make this official before we just start spouting off what we need. We'll put the list together over the next week or two, then collect the money at a gtg and send BMarc up to pick the stuff up.
Add what you need to the list as required. Verify prices here:
1. Air filter #1J0 129 620 ( 1998 to 2003 ) 5 or more: $11.25 each
Fyrman 1
2. Bosch Fuel Filter 1999 and up ( 0 450 906 288 ) c/w o-rings 5 or more $27.70 each
Fyrman 1
3. Sway Bar Bushing, 21mm / 23mm #1J0 411 314R/ T $3.10 each
Fyrman 4(T) &4(R) ...to have on hand for situations like last nite.
Some people are like Slinkies...... They're really good for nothing but still bring a smile to your face when you push them down a flight of stairs!
Fyrman is offline   Reply With Quote
Old August 26th, 2006, 19:22   #4
skenny
TDI(s): none
I could use a set of sway bar bushings!
2012 Carbon Grey 6spd GTI
skenny is offline   Reply With Quote
Page generated in 0.12988 seconds with 10 queries
[Output: 60.45 Kb. compressed to 53.74 Kb. by saving 6.71 Kb. (11.10%)]
