TRAMPLINEMAN
2012 JSW. Started the car tonight and both these lights were on. Drove the car about 10 miles home. Pulled a P2564 code. Did a search on here and found some info. Now, I've never done a bit of work on this car, always had the dealer do all the service cause I had warranty. In 119,988 miles, this is only the second time it's had the engine light come on. In my searching, I found that the wiring going to the sensor or actuator can possibly go bad. Is this the wiring that plugs in right above the passenger side axel shaft? Also, some said that this code could possibly be due to the vains in the turbo being full of soot and to clean them. Ok, where do I find this? I really don't want to disassemble things I don't need to.
Most of what I found on here when I searched this code was for older cars. Do those problems still pertain to the newer cars? I'm pretty mechanically inclined so I'm not afraid to tackle this, I just need to know where to look.
