dee_zell
A 1996 Passat hard to start when cold. Tried to extend the glow time but it doesn't seem to work with the Vagcom procedure explained in the How-To's. Help please.
It's my friend's car with 320K Kms on the odo. GPs has never been changed. No fault codes but as you mentioned timing might be an issue. Can I use Vagcom to check it?wrenchman30 said:if your glow plugs are working correctly its most like timing.
Okay, timing checked and within the specs. All glow plugs get power. No fault codes, engine is responsive and once it warms up it has no startup issues but when cold it cranks unacceptably long before it starts choking and shaking scaring everybody inside.wrenchman30 said:i would recomend using the timing tools to check the base timing on the engine. with that many miles i would recomend you read the broken glow plug removal posts and then decide to change them. they probably arent working correctly. check for voltage at the glow plugs you can use a test light hooked to battery positive and touch to the terminal on the glow plug and if it lights up usually the glow plug is good.
Ouch! No tools, will have to look for some service. This car has always been run on mineral oils changed religiously every 3000 miles. Is it OK?Joe_Meehan said:Check the compression.
The timing is within specs but retarded.Joe_Meehan said:You still might try adjusting the timing. Tweeting it may help.
Mineral oils? What about full synth 5/40 every 10K.dee_zell said:Ouch! No tools, will have to look for some service. This car has always been run on mineral oils changed religiously every 3000 miles. Is it OK?
