I've been reading most of the threads on this topic for the last several weeks seeking the cure to my tranny problems.
The car is a 2001 jetta 2.0 l gasser with the following problem, currently
it will down shif hard into 3rd gear while exiting off the hiway at speed, that being 65 + mph foot on gas. When I back off the gas the RPM's drop way down then back up & she downshiftes into 3rd & I'm in limp mode. Can pull over & turn off the ignition & fire it back up and it's good to go.
I have flushed 2 gallons of valvoline max life atf through it & changed the filter.
Car was had for $600 but have already bought a set of rokkor struts & shocks, ball joints, coil pack plugs wires etc. It runs great, engine is strong and tight as far as leaks go. Need a SAI pump which was stuck solid.
Anyway Things I have noticed since buying the car are the RPM's will fluctuate if i remove foot from gas pedal at hiway speed. Before I changed fluid I did notice that no or little rpm drop when i pulled back on gas at speed, now it will drop off stead, some times drop to ~ 1000+ rpm then bounce back up, it has a rhythmic fashion to it, 2-3 second up then 2-3 seconds down.
This has happened about 4 or 5 times since changing the fluid & filter.
On the original drain I pulled `2.3L , on the refill I started with 3 L ran the engine to op temp on dash gauge then opened the drain plug until fluid was still pulsing out, not a steady flow & capped it. The amount was ~ 0.5l, so initial drain was 2.3l & refill was 2.5l . Took a spin & shifting improved , drove maybe 60 miles & repeated the above this time I found the code block in vag-com to monitor the atf temp. I did the fluid level check procedure & drained 275ml. I Cleared the codes with vag-com & took it for a drive. Shifting was better than before the flush but still not 100 %.
After another 100+ miles I drained the pan again this time i drained `1725ML [1.725l] on the refill I added back the 275ml from previous level check + another `100ml for a total of 2200ml basically a little over a quarter cup of fluid. I added it after reading other posts suggesting a little extra may improve trans shifting. T o me it seems to have helped.
I'm now getting this:
00652 - Gear Monitoring 27-10 - Implausible Signal - Intermittent
Before the flush I noticed flaring, rough shift, delayed shift into D . Thought it felt like it was in neutral at hiway speed a couple of times. I'm not used to an auto trans other 2 cars are sticks.
here is the complete scan. also the batt needs replacement that may have something to do with this.
Thursday,22,May,2014,18:23:30:49413
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.2.0
Data version: 20140212
Mileage: 207350km-128841mi Repair Order: full scan 5-22-14
Chassis Type: 9M - VW Jetta IV (1998 > 2014)
Scan: 01 02 03 08 09 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57
75 76
Mileage: 207350km/128841miles
Address 01: Engine Labels: 06A-906-032-AVH.lbl
Part No: 06A 906 032 BQ
Component: 2.0l R4/2V G *3657
Coding: 00003
Shop #: WSC 00126
VCID: 6EDDC4C72A56006E79B-5178
2 Faults Found:
16795 - Secondary Air Injection System
P0411 - 35-00 - Incorrect Flow Detected
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - Intermittent
Readiness: 0000 0000
Address 02: Auto Trans Labels: 01M-927-733.lbl
Part No: 01M 927 733 JF
Component: AG4 Getriebe 01M 4833
Coding: 00011
Shop #: WSC 00000
VCID: 7DFFF38B77306BF6F01-0962
1 Fault Found:
Address 03: ABS Brakes Labels: 1C0-907-37x-ABS.lbl
Part No: 1C0 907 379 C
Component: ABS FRONT MK60 0103
Coding: 0004097
Shop #: WSC 00066 000 00000
VCID: 2A5508D7863E2C4EE53-5178
No fault code found.
Part No: 6Q0 909 605 F
Component: 04 AIRBAG VW6 0202 0003
Coding: 12340
Shop #: WSC 00066
VCID: 3A753897269E9CCE953-515A
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 16: Steering wheel Labels: 1J0-907-487-A.lbl
Part No: 1J0 907 487 B
Component: Lenkradelektronik 0001
Coding: 00008
Shop #: WSC 00066
VCID: 30611ABFF0E2569E2B7-5266
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J0 920 905 K
Component: A4-KOMBIINSTR. VDO V52
Coding: 07232
Shop #: WSC 00066
VCID: 2F6319C3EDDC496632D-515A
Subsystem 1 - Part No: IMMO
Component: IDENTNR: VWZ7Z0Y2844035
IMMO-IDENTNR: VWZ7Z0Y2844035
1 Fault Found:
01176 - Key
Part No: 6N0 909 901
Coding: 00007
Shop #: WSC 00066
VCID: F0E15ABFB062969EEB7-5178
Address 46: Central Conv. Labels: 1J0-959-799.lbl
Part No: 1J0 959 799 AJ
Component: 61 Zentral-SG Komf. 0001
Coding: 04097
Shop #: WSC 00066
VCID: 860D1C67A2E6A82E21B-4B18
Subsystem 1 - Part No: 1J1959801C
Component: 61 Tõrsteuerger. FS0002r
Subsystem 2 - Part No: 1J1959802D
Component: 61 Tõrsteuerger. BF0002r
Subsystem 3 - Part No: Steuerger
Component: t HL antwortet nicht
Subsystem 4 - Part No: 1J4959812C
Component: 61 Tõrsteuerger. HR0002H
6 Faults Found:
01330 - Central Control Module for Central Convenience (J393)
53-10 - Supply Voltage Too Low - Intermittent
01333 - Door Control Module; Rear Left (J388)
49-00 - No Communications
01331 - Door Control Module; Driver Side (J386)
00913 - Window Regulator Switch; Front Right Driver (E81)
01332 - Door Control Module; Passenger Side (J387)
01334 - Door Control Module; Rear Right (J389)
Address 56: Radio Labels: 1J0-035-18x-56.lbl
Part No: 1J0 035 180 D
Component: RADIO 3CP 0002
Coding: 02401
Shop #: WSC 00066
VCID: 2041EAFFA002E61EBB7-4B18
End ---------------------------------------------------------------------
Thanks for any input .
Bob G.
75 76
Coding: 00003
Shop #: WSC 00126
2 Faults Found:
Coding: 00011
Shop #: WSC 00000
1 Fault Found:
Coding: 0004097
Coding: 12340
Shop #: WSC 00066
1 Fault Found:
Coding: 00008
Shop #: WSC 00066
Coding: 07232
Shop #: WSC 00066
1 Fault Found:
01176 - Key
Coding: 00007
Shop #: WSC 00066
Coding: 04097
Shop #: WSC 00066
6 Faults Found:
Coding: 02401
Shop #: WSC 00066
Bob G.
