Hi,
My coolant is/was leaking when the engine is running at a higher capacity (going up into the mountains). It is a 98 Jetta TDI. A shop told me that I could use O'Reilly 50/50 AntiFreeze. Well, I am now told that you cannot mix the the G12 with any other anti-freeze - that it will cause great harm to the engine. Am I hosed? Can I flush all of the anti-freeze? What causes coolant to leak when the engine is running at a higher RPM?
I appreciate your help.
Todd
Todd
