98 NB TDI 1.9 Manual Transmission Gear Selector Lever
UBUGME
Jacksonville, FL
2015 VW Golf Sportwagen Gray
Can somebody please provide the part number for the 98 NB TDI 1.9 Manual Transmission Gear Selector Lever and, if possible, how to replace it?
Burl4561
JAX, FL
-'02 Golf 4dr
The replacement is pretty striaght forward, assuming it is like the cast ones on the other 5 speeds. Remove the cable by removing the clip and pin. There is a nut on top of the jagged round hole. Remove the nut and either use a gear puller or some gentle prying to loosen the taper fit.
I looked at my 98' bug and don't see this part, so I can't help you with the part number.
Dieselgeek
TDIClub Enthusiast, Vendor , w/Business number
Golden, CO
2016 Golf TDI
1j0 711 051b
This program won't let me capitalize the letters...
UBUGME
Jacksonville, FL
Thank you. I got the part and installed it. I had to take out the battery in order to have room.
