RUGsux72
- Joined
- Jan 10, 2009
- Location
- Richmond, VA
- TDI
- 2012 Jetta TDI w/DSG & 2013 Beetle Convertible TDI w/DSG
Airbag light came on my '03 Beetle. Ran VCDS scan and came up with the following results:
Friday,23,March,2018,16:51:38:32225
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 17.8.1.0
Data version: 20171130 DS276.6
www.Ross-Tech.com
VIN: 3VWCD21Y63M321993 License Plate:
Chassis Type: 1Y (1C - VW New Beetle (1998 > 2010))
Scan: 01 02 03 08 15 17 19 25 29 35 37 39 46 54 56 65 75
VIN: 3VWCD21Y63M321993 Mileage: 227090km-141107miles
Address 01: Engine Labels: 06A-906-032-AWV.lbl
Part No: 06A 906 032 KT
Component: 1.8l 5VT NB AG6 G 4926
Coding: 00004
Shop #: WSC 00066
VCID: 7AF1FDCA66A2B896DF-515A
3VWCD21Y63M321993 VWZ5Z0C2252217
No fault code found.
Readiness: 0110 1101
Address 02: Auto Trans Labels: 09G-927-750.clb
Part No: 09G 927 750 P
Component: AQ 250 6F 0324
Coding: 0000008
Shop #: WSC 00000 000 00000
VCID: 3E7931DA6A0A54B6A3-513C
Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
Part No: 1C0 907 379 M
Component: ESP FRONT MK60 0102
Coding: 0019970
Shop #: WSC 00066 000 00000
VCID: 346D13F254468EE645-515A
Address 15: Airbags Labels: 1T0-909-605.lbl
Part No: 6Q0 909 605 E
Component: 08 AIRBAG VW7 0517
Coding: 0012344
VCID: 397322C67324738E96-513C
1 Fault Found:
00003 - Control Module
014 - Defective
Address 17: Instruments Labels: 1C0-920-x4x.lbl
Part No: 1C0 920 941 N
Component: KOMBI+WEGFAHRS. M73 V03
Coding: 03234
Shop #: WSC 00000
VCID: 2B5F088ED978D11E14-4B18
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN V032
Coding: 00006
Shop #: WSC 00066
VCID: 70E5DFE230DEF2C661-4B18
All connectors have been checked. Battery voltage is 12.74vdc at rest...14.15 running. Unable to reset airbag controller. Currently performing the Sunday afternoon battery cable clamped reset to see if that works. If that doesn't work, what's my next step?
www.Ross-Tech.com
Coding: 00004
Shop #: WSC 00066
Coding: 0000008
Coding: 0019970
Coding: 0012344
1 Fault Found:
014 - Defective
Coding: 03234
Shop #: WSC 00000
Coding: 00006
Shop #: WSC 00066
