Old April 14th, 2019, 21:24   #1
Bewtdi
TDI(s): 2004 Golf
Default 2004 Golf bew 16725
Hi I recently bought a 2004 golf tdi in which I had a coolant temp sensor cel. I replaced that and rescaned and found out
I have a cel 16725 camshaft position sensor circuit-out of range/performance. Does anybody have any ideas on how to fix this thanks.
Bewtdi is offline   Reply With Quote
Old April 15th, 2019, 02:44   #2
Tdijarhead
Check the wiring, unplug and replug the connector a couple of times if the wiring is intact and the unplugging/plugging trick doesn’t work, replace the sensor. The connector is right on the front of your engine behind the oil filter canister.
There are two connectors there one is grey, one is black. One goes to the cam sensor, the other to the crank sensor. The sensor itself is under the corner of the timing belt cover which you’ll have to remove. Do not drop anything down into the timing belt path. Or this will happen.
http://forums.tdiclub.com/showthread.php?t=477509
You may also want to pull your valve cover and inspect your cam while your at it. The 04 & 05 engines have a known issue with cam wear.
Old April 15th, 2019, 08:01   #3
JB05
Fuel Economy: 43/41/40
A new grommet will also be needed if you do change the cam sensor. Be choosy where you purchase the new sensor.
JB05 is offline   Reply With Quote
Old April 15th, 2019, 09:24   #4
oilhammer's Avatar
Fuel Economy: fantastic
Yeah, just order a new grommet. Yours will be petrified and will not go back in.
www.cardocautomotive.com
Old April 15th, 2019, 21:55   #5
Bewtdi
TDI(s): 2004 Golf
Thanks for the advise everyone. Anyone know a good brand of cam sensor I should look for ? ( I live in Calgary).
Old April 16th, 2019, 03:29   #6
JB05
Try the dealer. That way you know the part is genuine. I found out the hard way.
2004 mk4 golf 1.9tdi BEW NOT STARTING! PLEASE HELP TyMiller18 VW MKIV-A4 TDIs (VE and PD) 17 October 28th, 2018 10:32
WTB - Stock 2004/5 BEW Golf downpipe Sooch Private TDI Items for Sale/Wanted 1 August 1st, 2016 12:49
2006 Golf TDI codes 16725, 17524, engine wiring problems? brkdrvr VW MKV-A5 Golf/Jettas 4 November 14th, 2015 07:45
2004 Golf TDI (BEW) Turbo Replacement FeraTechInc VW MKIV-A4 TDIs (VE and PD) 20 March 12th, 2015 18:46
2004 Golf BEW needs new turbo /nozzles Curkkic Private TDI Items for Sale/Wanted 2 September 8th, 2013 13:29
Page generated in 0.13462 seconds with 13 queries
[Output: 72.14 Kb. compressed to 63.22 Kb. by saving 8.92 Kb. (12.36%)]
