Old April 15th, 2019, 08:35   #1
McGuillicuddy
Fuel Economy: 5.6 L/100km
Default Best treatment for surface rust on rockers under mudguards?
The previous owner of the Battle Wagon installed Votex mudguards but underneath those the paint on the rockers is flaked off enough to leave a couple inches expose metal, which unsurprisingly now has surface rust on it. Since it is almost completely covered by the mudguards I'm not too worried about what it looks like but I want to make sure to stop the rust in it's tracks so it doesn't get any worse.
I don't have a lot of experience in this area myself. Anybody able to recommend the best rust product for this application? POR15 seems an obvious choice but it sounds like a pain in the ass to work with and paint over (which would be required since it is UV sensitive and the sun will get at least the edges of it). Anything else?
Or am I overthinking this and am I better off to just go get a can of rust primer and some colour-matched paint?
'The Battle Wagon'
McGuillicuddy is offline   Reply With Quote
Old April 15th, 2019, 08:46   #2
Nyk
Nyk's Avatar
I feel your pain. My Jetta is starting to show rust around the same spot, and also on the arches of the quarter panels. I figure I'm just going to grab a replacement panel and repaint it, and then sand off the rust/paint/prime the rockers.
Hopefully the rust isn't too bad, but if it is I guess I'll just have to pony up for some new rockers. That little gap behind the mudflap/wheelwell is s death sentence to the rockers imo. :P
Nyk is offline   Reply With Quote
Old April 15th, 2019, 09:23   #3
Prairieview
I've used RustBullet (sold by Summit Racing) for years on Mk. II's and now Mk. IV. Really needs to be applied to bare metal. Not a quick-and-easy like you want.
Prairieview is offline   Reply With Quote
Old April 15th, 2019, 10:06   #4
McGuillicuddy
I'm not necessarily looking for quick and easy, but reliable and straightforward to use. POR15 for example, seems to be hit and miss even for people claiming to follow instructions to the letter. And there is also some disagreement on how to apply paint to it (best to apply while tacky or wait until dry and sand first? do I need to buy the Tie Coat primer?). It just doesn't seem as idiot-proof as I'd like, but if it is clearly the best product for the job I'll give it a go. I actually do have an unopened POR15 starter kit on-hand to use.
'The Battle Wagon'
Old April 15th, 2019, 10:45   #5
Nero Morg
Rustoleum. Used that on my pickup, rust hasn't come back yet after 3 years.
2003 Jetta Wagon silver
DLC1019, VNT17, 3bar map, BHW oil cooler, BRM intake, ARP's, 5 speed, ESP, & MFSW retrofit, Malone Stage 4 SB stage 3 endurance
Midwest Light Creation's HID headlights
And then the wife's 2014 Passat TDI SEL all stock
Nero Morg is online now   Reply With Quote
Old April 15th, 2019, 11:52   #6
leafs
TDI(s): alh
In the mean time u could apply some phosphoric acid and it will convert the rust to iron phosphate. The iron phosphate will be black and protect against more rust. Just be careful and not get it onto painted areas. It's the same chemical por 15 uses to prep the surface.
leafs is offline   Reply With Quote
Old April 15th, 2019, 11:55   #7
I just had my mechanic pull the front fenders and clean up the rocker rust. Moisture collects on the top of the rockers and can make holes in it, causing it to rust from the inside out. If you want to hold off rust repair I'd suggest you pull the fenders and use epoxy or similar on the tops of the rockers to keep the moisture out. Then paint with POR-15 or something else: I agree that feedback on POR-15 is mixed here. But I'm not sure what would be a better option.
The important thing with rust is what you see is usually only a fraction of what's there.
2002 Jetta wagon, 384K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 286K; '99.5 Golf, 260K; 2011 335d, 60K; 2015 Golf Sportwagen, 13K. Principal, http://www.idparts.com
Old April 15th, 2019, 21:02   #8
Prairieview
Plus, the sum***** never sleeps......
(I'm laughing...but, it ain't funny!!!!)
Old April 16th, 2019, 03:41   #9
JB05
Fuel Economy: 43/41/40
POR 15 did not save my right fender nor the front of the hood.
JB05 is offline   Reply With Quote
Old April 16th, 2019, 15:39   #10
turbocharged798
turbocharged798's Avatar
Fuel Economy: 40-50mpg
I have not had good luck with por15.
Regardless what they say, you CANNOT paint over rust, it will continue to grow underneath. Problem with rust is it drills into the base material and unless you sandblast it off or completely cut it out, it will come back over and over again.
99.5 Black Jetta TDI; DLC1019 nozzles, G60/VR6, ASV pistons, EGR delete, ASR/EDL, bilstein TCs MFA cluster.. Beater car. 395K miles and climbing.
09 Jetta Gasser, autofailmatic. Backup car. 230K.
turbocharged798 is offline   Reply With Quote
Old April 17th, 2019, 14:27   #11
VincenzaV
VincenzaV's Avatar
Fuel Economy: Better than a tank, worse than a cyclist.
Nero---Rustoleum. Used that on my pickup, rust hasn't come back yet after 3 years., which one? They make a few. You mean a rust converter from Rustoleum?
VincenzaV is offline   Reply With Quote
Old April 17th, 2019, 14:37   #12
Nero Morg
Yep that's the one. Don't think I have the can anymore, but it was clay in color, just used that on the underside of the bed and it's been that way since.
Old April 17th, 2019, 14:52   #13
Nyk
Nyk's Avatar
I've used Rustoleum about 8 years ago on my 89 Suzuki motorcycle when I first got it in an effort to redo the frame. Used a wire brush to get as much loose crap off as possible and then cleaned it up before spraying it on.
Been good ever since. Not sure if it was a rust converter or not, but it said I could use it to "paint right over rust" so I assume it probably was.
Old April 17th, 2019, 18:32   #14
C Squared
TDI(s): 2 02 TDI's
I have used Plasticote rust converter with pretty good results over the years.
Follow directions.
C Squared is offline   Reply With Quote
Old April 17th, 2019, 19:04   #15
VE1.9
Anybody ever use BlackStar?
Thinking of giving it a try this summer. It also comes in an aerosol.
http://www.mrochem.com/BlackStar-Rust-Converter.html
VE1.9 is offline   Reply With Quote
Injection pump and crank pulley surface rust? marshalldanielp TDI 101 1 November 18th, 2012 09:39
Cylinder surface corrosion/head gasket surface preperation dislexicmofo VW MKIV-A4 TDIs (VE and PD) 32 March 2nd, 2012 12:05
Rockers starting to rust. Rockerguard or Plasti-dip? flatlanded Upgrades (non TDI Engine related) 7 July 19th, 2011 20:29
Rust on Rockers bigmacblb VW MKIII-A3/B4 TDIs 6 October 21st, 2010 03:14
Jetta anti-rust treatment golightfoot TDI 101 10 March 10th, 2003 05:30
Page generated in 0.18471 seconds with 13 queries
[Output: 124.70 Kb. compressed to 104.09 Kb. by saving 20.60 Kb. (16.52%)]
