Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > VW MKVI-A6 Jetta Sedan (~ 2011+)
VW MKVI-A6 Jetta Sedan (~ 2011+) Discussions area for the MkVI (2011+) Jetta sedan. This model was originally codenamed NCS (New Compact Sedan).
Old April 15th, 2019, 13:50   #1
ckohler3
Default LED front turn signal bulb change
I bought pilot brand 1156 amber LEDs. I filed one of the nubs down a little so it would fit in the socket. I get a lamp out on the dash and the bulb doesn't light up. I tested the bulb to 12V and it works. I'm guessing I need the inline resistor. I only tried installing one but I don't think changing both would make a difference. I already changed the daytime running lamps to LED and had no issue. Any ideas?
Edit- got them both working. Had to bend the metal in a bit that holds the tit on one side. Bulb out light on the dash is on. I really don't want to splice in the resistor.
ckohler3 is offline   Reply With Quote
Old April 15th, 2019, 18:44   #2
Turbski
You will need a resistor in order to get the dash light to turn off. It reads the resistance of the wire to determine if the bulb is blown.
Turbski is offline   Reply With Quote
early A4 front turn signal bulb BobnOH TDI 101 0 August 25th, 2016 08:46
Day time running light bulb size, and front turn signal bulb size? Facetoface822 TDI 101 4 May 1st, 2012 10:44
Replacing Front Turn Signal Bulb Mass. Wine Guy VW MKIV-A4 TDIs (VE and PD) 0 May 2nd, 2005 06:40
What kind of bulb for front turn signal? It's out. STRANGETDI VW MKIV-A4 TDIs (VE and PD) 7 February 27th, 2004 08:51
Turn signal - bulb change itsfatboy VW MKIV-A4 TDIs (VE and PD) 5 February 2nd, 2004 20:47
Page generated in 0.12146 seconds with 13 queries
[Output: 52.14 Kb. compressed to 48.07 Kb. by saving 4.07 Kb. (7.81%)]
