benlong7777
Having trouble getting my 2011 Jetta Sportwagen tdi to go into regen. Ran a autoscan (below). Got two different codes related to the DPF. Tried to force the regen using the Ross tech wiki instructions, both idle and driving. Could not get either to work. When doing the driving all went well following the directions, but every time I went back to the DPF regen adaption channel the value was returned to zero. Is this suppose to happen? How do you tell that the car is in regen? Could it not be going into regen because the soot levels are to high? It reads at 51grams. What should my next step be? If I take it to VW will it most likely be the filter itself and be covered under the emissions warranty?
Thanks for the help.
Thursday,06,March,2014,16:29:13:14007
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.2.0 (x64)
Data version: 20140212
VIN: 3VWML7AJ1BM666662 License Plate:
Mileage: 64130 Repair Order: glow plug diesel light 1
Chassis Type: AJ (7N0)
Scan: 01 03 08 09 15 16 17 19 1C 25 42 44 46 52 56 62 72 77
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
1C-Position Sensing -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (CJA) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 906 019 DA HW: 03L 906 019 DA
Component: R4 2,0L EDC G000SG 8217
Revision: 12H14--- Serial number:
Coding: 0050072
Shop #: WSC 00066 000 00000
VCID: 6DD1CFCA74A74976401-8038
2 Faults Found:
009304 - Diesel Particulate Filer
P2458 - 000 - Regeneration Duration - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 101171 km
Time Indication: 0
Date: 2034.14.05
Time: 07:23:08
Freeze Frame:
RPM: 1656 /min
Speed: 27.0 km/h
Mileage: 520 km
26.7
30.3
Pressure: 0 mbar
milliliters: 60 ml
009315 - Diesel Particle Filter
P2463 - 000 - Excessive Soot Accumulation - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 255
Mileage: 101315 km
Time Indication: 0
Date: 2034.14.07
Time: 16:14:20
Freeze Frame:
RPM: 1771 /min
Speed: 47.0 km/h
Pressure: 62 mbar
Hex Value: 0xFF40
Temperature: 234.0°C
(no units): 117.3
Mileage: 660 km
Readiness: 1 2 0 0 0
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BG HW: 1K0 907 379 BG
Component: ESP MK60EC1 H31 0106
Revision: 00H31001
Coding: 114B600C49280000881106EA921B0042B70000
VCID: 78FFEE9ECBE5FCDEA37-802D
No fault code found.
Address 08: Auto HVAC (J301) Labels: 7N0-907-426.clb
Part No SW: 7N0 907 426 L HW: 7N0 907 426 L
Component: AC Manuell H17 0202
Revision: 00012001
Coding: 0000001002
Shop #: WSC 00066 000 00149
ASAM Dataset: EV_Climatic A01005
ROD: EV_ClimaBasis_SE36.rod
VCID: 3D713F8AAC4719F6B01-8068
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 5K0 937 084 G HW: 5K0 937 084 G
Component: BCM PQ35 B 011 0045
Revision: BG011001
Coding: 2D380E1A902F3EC4008800817000004441000086535D056064 8020200040
VCID: 366320A68171CAAE71B-8063
Subsystem 1 - Part No: 5K1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 11011 26 0512
Coding: 009795
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 5K0 959 655 B HW: 5K0 959 655 B
Component: AirbagVW10G 021 0706
Serial number: 003C4R01JB7+
Coding: 00003044
ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 39792B9AB86F25D69C9-806C
Seat occupied recognition:
Subsystem 1 - Part No SW: 1KM 959 339 HW: 1KM 959 339
Component: BF-Gewichtss. 007 0001
Serial number: ---0000R--0005H13900
Crash sensor for side airbag; driver side:
Subsystem 2 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME013A2458ZZZQ
Crash sensor for side airbag; passenger side:
Subsystem 3 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME5E2C3259ZZZ3
Crash sensor for side airbag; rear driver side:
Component: S.Sens.Fahr.H --- ----
Serial number: 3511HSME73202E25ZZZG
Crash sensor for side airbag; rear passenger side:
Component: S.Sens.Beif.H --- ----
Serial number: 3521HSME6C4F2325ZZZV
Crash sensor for front airbag; driver side:
Component: F.Sens.Fahr --- ----
Serial number: 35527SME08193625ZZZA
Crash sensor for front airbag; passenger side:
Component: F.Sens.Beif --- ----
Serial number: 35627SME05083725ZZZ7
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 507 BC HW: 5K0 953 549 E
Component: Lenks.Modul 007 0080
Revision: -------- Serial number: 90422JL6000SK
Coding: 108A140000
Shop #: WSC 00066 000 00158
ASAM Dataset: EV_SMLSNGKUDS A05001
ROD: EV_SMLSNGKUDS_SE36.rod
VCID: 72EBDCB6A599968E9D3-8027
Multi Function Steering Wheel Control Module:
Subsystem 1 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H07 0013
Serial number: 0212406
Coding: 820000
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 5K0 920 971 C HW: 5K0 920 971 C
Component: KOMBI H23 0204
Revision: X0023007 Serial number:
Coding: 270F01
ASAM Dataset: EV_KombiUDSMM9RM10 A04203
ROD: EV_KombiUDSMM9RM10_VW36.rod
VCID: 2F6D15C2762BFB6632D-807A
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 C HW: 1K0 907 951
Component: J533 Gateway H37 0614
Revision: H37 Serial number: 17011101210536
Coding: 352002
VCID: 306F16BE6315E49E2B7-8065
Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
Part No SW: 5N0 919 879 HW: 5N0 919 879
Component: Kompass 001 0001
Revision: 00001000 Serial number: 1225223RB7GB06
Coding: 0000002
VCID: FEF37886A9C142EE69B-80AB
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 920 971 C
Component: IMMO H23 0204
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_ImmoUDSMM9RM10 A01200
ROD: EV_ImmoUDSMM9RM10_SE36.rod
VCID: EADB44D60D49DE4EA53-80BF
Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 561 959 701 HW: 3C0 959 793 B
Component: TUER-SG FT 002 0501
Revision: 13110009 Serial number: 0001838873
Coding: 0004B5
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_TSGFPQ35BRFVW46X A04001
ROD: EV_TSGFPQ35BRFVW46X.rod
VCID: DBB51112D213B7C62E5-808E
Slave Driver:
Subsystem 1 - Part No SW: 1K0 959 703 AH HW: 1K0 959 795 T Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 006 1401
Serial number: 00000005355185
Coding: 000490
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 70 3001
Revision: 00H17000
Shop #: WSC 02069 000 90108
VCID: 316913BAA81FED96249-8064
Address 52: Door Elect, Pass. (J387) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 561 959 702 HW: 3C0 959 792 B
Component: TUER-SG BT 002 0501
Revision: 15110009 Serial number: 0001837602
Coding: 0004B4
ASAM Dataset: EV_TSGBPQ35BRFVW46X A04001
ROD: EV_TSGBPQ35BRFVW46X.rod
VCID: DCB7120ED71DB0FE27F-8089
Slave Passenger:
Subsystem 1 - Part No SW: 1K0 959 704 AH HW: 1K0 959 794 T Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 006 1401
Serial number: 00000005297229
Coding: 000490
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1K0 035 180 AC HW: 1K0 035 180 AC
Component: Radio Prem-8 H15 0043
Revision: -----27S Serial number: VWZ4Z7L3137570
Coding: 0500040004
VCID: 61C9A3FA787F1D16F49-8034
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 21
Mileage: 95823 km
Time Indication: 0
Date: 2030.14.20
Time: 17:11:55
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 C HW: 7P6 035 730 C
Component: TELEFON H05 0440
Revision: 1B001001 Serial number: 00007669067065
Coding: 0A00000000010100
ASAM Dataset: UHVNA A01007
ROD: UHVNA.rod
VCID: 326B1CB66519D68E5D3-8067
End ---------------------------------------------------------------------
Coding: 0050072
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 101171 km
Time Indication: 0
Date: 2034.14.05
Time: 07:23:08
Freeze Frame:
RPM: 1656 /min
Speed: 27.0 km/h
Mileage: 520 km
26.7
30.3
Pressure: 0 mbar
milliliters: 60 ml
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 255
Mileage: 101315 km
Time Indication: 0
Date: 2034.14.07
Time: 16:14:20
Freeze Frame:
RPM: 1771 /min
Speed: 47.0 km/h
Pressure: 62 mbar
Hex Value: 0xFF40
(no units): 117.3
Mileage: 660 km
Revision: 00H31001
Revision: 00012001
Coding: 0000001002
Revision: BG011001
Coding: 009795
Coding: 00003044
Coding: 108A140000
Coding: 820000
Coding: 270F01
Coding: 352002
Coding: 0000002
Coding: 000000
Coding: 0004B5
Slave Driver:
Coding: 000490
Revision: 00H17000
Coding: 0004B4
Slave Passenger:
Coding: 000490
Coding: 0500040004
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 21
Mileage: 95823 km
Time Indication: 0
Date: 2030.14.20
Time: 17:11:55
ROD: UHVNA.rod
