terrydtdi
As soon as I put a fuse in for the cigarette lighter it blows. I pulled the lighter assembly out of the console to clean it, and make sure there wasn't anything in there causing a short.
If I unplug the socket the fuse is fine, then when I connect the plug it will short and blow the fuse.
It appears the lighter socket doesn't come out of the housing. Will I need to buy the whole assembley?
